Shoe Box Bench
2,515
45
Posted in HomeOrganizing
Introduction: Shoe Box Bench
In Hawaii, we take our shoes off at the door. Consequently, the floor inside our front door was often cluttered with shoes and sandals. Sometimes it is easier to put shoes on sitting down.
After thinking about the storage and sit problems for awhile, Sketchup was used to sketch a box/bench that would fit in the space between the open door and duplex outlet.
Step 1: Get Ready
An inventory of what I had laying around, precipitated a trip to Home Depot.
Cut 1 x 12 Home Depot common board into 9 pieces.
  • (1) 32"
  • (1) ~ 30.25"
  • (2) 16"
  • (5) 5"
Cut two pieces from a scrap of 1/4" plywood.
  • (1) 12" by 32"
  • (1) 12.75" by 32"
Step 2: Assemble Box
I used glue and finishing nails to assemble the box. Once glue set, the dividers were fixed in place using same glue and finishing nails method. My 5 dividers were used to make 6 equal size shoe pockets. You might want more smaller pockets or fewer bigger pockets depending on your footwear.
Glue used was West System G/flex Toughened Epoxy. I have used G/flex before to laminate cedar for a Greenland style paddle. The glue alone is probably strong enough, but nails make it stronger and helped hold the box in position while the glue cured.
Step 3: Assemble Lid
The lid has four parts plywood, foam, fabric and common board.
  • Common board tapered and shaped to fit the top of the box.
  • The foam cut from a camping sleeping pad. Cut lines had been traced from 12.75" by 32" plywood piece.
  • Foam and plywood wrapped with fabric.
  • Fabric stapled in place.
  • Common board screwed to covered foam/plywood.
Step 4: Fill With Footwear
Shoe Box Bench should probably be painted, but it already has shoes and sandals in it.
Shoe Box Bench is bottomless so dirt can fall through to be swept or vacuumed up.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    2 Comments
    Hello,
    As the Box Bench is bottomless we should be careful in rainy seasons, because we would be surprised when we will find some wired insects in our shoes,
    I have been meaning to make something like this for my mudroom for a long time. Thanks for sharing the plans.
