Shoe Cubbies
6,274
211
11
Posted
Introduction: Shoe Cubbies
We're constantly having family and guests over. Even with just my family alone there seems to be at least 25 people over! Needless to say, when that happens, our mud room becomes a sea of shoes. Added to my honey-do list that summer was to build custom cubbies to tame the mess.
Step 1: Top and Side Frame Panels Cut
Top 67" x 12"
Sides 59 ¾" x 12"
Notch ripped along inside edge for back panel insert.
Horizontal shelves are 64 ½“ x 11 ¾”
Vertical shelves are 58 ½” x 11 ¾”
Step 2: Pocket Screws Drilled to Attach Frame Corners
Step 3: Frame Screwed Together
Step 4: Added Metal Corner Brackets for More Stability
Step 5: Marked Slots for Shelves and Cut With Jigsaw
It was critical to get this right for the cubby dimensions and to ensure to mark horizontal vs. vertical shelves. I wanted to cubes to be 10 ½” x 10 ½” to allow for shoes or those box inserts in case we wanted to use those for things other than shoes. Bottom cubes were slightly taller (14½”) to allow for boots.
Step 6: Shelf Slots Cut
Slots cut every 10½” for the horizontal shelves just slightly past the ½ way point of the board. I used a jigsaw to cut the sides and chisel on the edge to remove the section.
Step 7: Shelves Cut!
Step 8: Shelves Inserted Into One Another
Step 9: L Brackets Installed on Shelves by the Frame
If I were to do this again, I would have notched the frame on the inside and made the shelves a few mm longer to allow them to slide into the frame. This would have added more stability and prevented the end shelves from moving without the need for the "L" brackets.
Step 10: Back Panel Cut to Fit
1/4" panel cut to fit and layed into slot cut in back of frame from step 1. Panel secured with finishing nails.
Step 11: Paused to Admire the Progress!
Step 12: Building Base
The base of the cubbies was made from 2x4's screwed together and pocket screwed to the shelves.
Step 13: Base Was Brought Forward in Front and Back and Bottom Attached
This was done to accommodate the finishing trim on the front and the trim on the wall (you'll see what I mean later).
Step 14: Measuring Crown Molding for the Top
Step 15: Created 2x4 Box on Top
I decided to create some additional storage at the top behind the crown molding.
Step 16: Added Frame Trim and Lined Up the Crown Molding for the Top Box
Used painters tape to hold the angles and line up the corners.
Step 17: Finishing Trim Glued and Nailed to Front of Shelves
Step 18: Base Board Trim Added to Bottom
Notice how the baseboard trim on the frame pops out? This is why I popped the base out slightly so the frame trim wouldn't overhang the baseboard trim.
Step 19: Added Some Filler Pieces to Secure the Crown
2x4 ripped and cut at a 45 degree angle met up perfectly. I wanted to add this for more stability for the crown and so things can be stored on top as well. Additionally, I did not to leave a gap since the top would be used for storage. Finishing nails were used to install the crown molding.
Step 20: Notches Chiseled for the Lid Hinges
Step 21: Lid Measured and Cut
Edges ripped at 45 degree angle to fit against the crown molding.
Step 22: Lid Attached
I don't have any pictures but there's a small storage area once you lift the lid. I haven't added a handle or toy chest hinge to hold it up yet.
Step 23: 2 Coats of Stain and Polyurethane Applied
Step 24: Staggered Base in Action!
Remember I opted to move the base forward slightly? Here's why I did it in the back too. Having the gap allows for the unit to sit up flush against the wall without the existing baseboard trim to be cut.
Step 25: Bring on the Shoes!
Notice the wellies and tall boots are accommodated perfectly in the larger cubbies at the bottom. This thing was big and HEAVY so take that into consideration if you're going to take this project on.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    11 Comments
    Oops sorry. Finger fault (new phone). Anyhow pls add it to the "honey - do" list. Book a ticket and come and show me (? make the same one). Oh, there are...mhh a bit more to do. A holiday in exchange for some "honey to do". How does that sound. Marietjie South Africa. (serious)
    Can you pls book a ticket for you and your "honey do"
    nice, what grade and type of wood did you use? What was the approximate cost and time?
    I used a maple plywood. It took about 5 weekends (stain and poly was 2 weekends) and roughly $300.
    What brand and color stain and what sheen of poly did you use?
    The stain is Minwax wood finish oil based stain applied with a sponge brush and cloth wiped (2x). I believe the color is espresso. For the finish I used 2 coats of Minwax Fast Dry Polyurethane in semi-gloss. I added an additional coat of poly for the shelf bottoms as those would take the most wear from the shoes, dirt, water, etc.
    Brilliant build! I love it
    awesome job!
