3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Shoe Tower - a free standing, multi-tier floating shoe rack
Shoes take up a lot of space. This is a known fact.
In a room as small as mine, space is valuable and the shoe pile that I used to maintain in one corner of my room often became unmanageable as the shoes spread out across my room and enveloped what little floor space I had.
Not any more! With a combination of the Ikea floating shoe rack and some ideas of my own, I've created this free standing shoe rack/tower which stores my shoes in an attractive way without the need for cardboard boxes or shelves. WIN!
This design is easily expandable and the strength of the steel bars I've used to support the shoes means it could easily be extended to house 3 pairs of shoes side by side. It would also be easy to build one which extended up higher to accommodate more shoes than I have.
I've entered this into the Homemade Christmas competition as I think it'd be a great gift for any of the disorganised people in your life.
I hope you like it! Comment and rate please.
Step 1Gather tools and materials
Here's a list of tools and materials that you'll need to complete this project.
Tools:
  • screw driver
  • tennon saw
  • hacksaw
  • carpenters square
  • some clamps
  • pencil
  • pretractor
  • drill with 3mm and 5mm bits
  • a scrap of sandpaper
Materials:
  • 1 2100 x 70 x 18mm planed timber
  • 3 1m lengths of 4mm threaded steel
  • 6 1.25" x 8 screws
  • 18 4mm nuts
Approximate cost: £10
73 comments
1-40 of 73next »
May 20, 2012. 9:46 PMpjdubber says:
I finally got around to making this shoe rack and I expanded on it a bit. My total width was 3'6" or 42" or 1067mm (for you brits!) with an additional "leg" in the middle. I stained the wood, spray painted black enamel on all nuts, washers, and threaded steel (1/4") and got some clear vinyl tubing (1/4" inner diameter) to cover the threaded steel where it contacts the top of the shoe (not bottom).  I tried to slide on the tubing but it was a bit too snug, so I sliced the tubing lengthwise and slipped it on.  I also varied the spacing for each level and made the top level two different sizes (see SketchUp pic for the middle "leg" measurements).  Please feel free to use these pics in your final step and thank you very much for posting such a great idea!
And yes, I did have to thread the nuts all the way to the middle leg!  :p
Jan 15, 2010. 6:32 PMSunbanks says:
I think when I do this I'll use wooden dowels instead of the threaded steel, and then I'll paint it a nice color :D Like purple.
Mar 21, 2010. 12:44 PMHoudinipeter says:
 did you ever finish that? That looks like a good way to go..
Mar 21, 2010. 1:31 PMSunbanks says:
Not yet, I still need to get the dowels.
Jun 10, 2010. 3:06 PMSunbanks says:
Haha I STILL haven't gotten them!
Jun 20, 2010. 6:10 PMdvnfntn says:
NOW?????!!!!!
Jun 20, 2010. 6:11 PMSunbanks says:
Nope :P
Apr 25, 2010. 1:12 PMj626no says:
 if you used acorn nuts on the outside surface, it might make it look a little nicer (since you were worried about the threaded rods sticking out beyond the wood)
Mar 22, 2010. 5:23 PMCrawJac says:
 It's a great idea, I used the same hole spacing and used 1/2" dowel rods. It worked great and I was able to paint it. But, I would suggest NOT drilling all of the way through the sides b/c the ends can be tough to sand and paint.
Mar 20, 2011. 2:06 AMGreenehouse says:
Great project idea, thanks for posting it. I agree with the suggestions of threading a nut on BEFORE cutting the rod. Once it's cut you just unscrew the nut and it cleans up any burrs or nicks and it's easy to re-thread the nut. You could recess the outside nuts into the legs so they don't stick out if that is a concern. Again, great project!
Dec 15, 2010. 5:23 PMHibatchi cow says:
Ok i am sorry this is kinda unrelated but i have those black Salomons and they are awsome
Jun 14, 2010. 6:29 PMEye Poker says:
I'm thinking some brass colored rods and a bit of stain....
Jun 5, 2010. 4:02 PMah-el says:
merci for live
May 3, 2010. 8:37 PMEggHead101 says:
Great idea.
Also instead of using metal rods, you can use wooden dowels and wood glue for a more "natural" look. Maybe even Bamboo for a splash of oriental flair..
May 2, 2010. 2:40 PMColeman Demo says:
For us yanks that don't have a metric measuring tape, including standard measurements would be helpful.
Apr 5, 2010. 3:53 AMKryptonite says:
I have wanted to make a cardboard one for a while now but have been preoccupied with other passtimes.
Mar 2, 2010. 2:23 AMbelti says:
Awesome I'll try that , thanks.
Jan 6, 2010. 2:02 PMMcGrep says:
Finally, an affordable, economical DIY shoe rack with a polished outcome. It certainly surpasses the original ideas I had in mind for my shoe organization woes.  Excellent!
Dec 17, 2009. 2:48 PMseth556 says:
So far I've made 2, the first one didn't turn out very well but the second turned out great. The first I used cheap wood and thought using wooden dowels would look better and be cheaper than the threaded rod but that didn't turn out as planned. Stick to the threaded rod if you're going to build this, trust me.
The second turned out great. Well it's not quite done, I still need to go get some more washer and nuts for the rods. But other than that still yet to be completed it looks awesome. I used pine wood which looks great and is pretty cheap, about $9 on wood and $4 on the rods, so under $15 with all the hardware. Great simple project.
Dec 17, 2009. 3:40 PMseth556 says:
of course
Dec 18, 2009. 5:24 AMseth556 says:
Abolutly.
I also changed the angle for the tower from the 75 degrees to 60 so it wouldn't want to fall backward.
Dec 10, 2009. 5:34 PMk7_avenger says:
I'd suggest putting the nuts on the bar before cutting it. Sometimes cutting a threaded bar leaves a really gnarly end, and it can be next to impossible to get a nut on there. The other option is to thread the nut all the way down from the other end, which would get pretty irritating.
Dec 28, 2009. 1:39 PMyokozuna says:
Also, getting a nut started on such a cut can sometimes be a task.  If you take it back off, that will knock off the extra shards meaning you can then start the nut on it where you couldn't before.
Dec 10, 2009. 12:50 PMJouda Mann says:
 How does this effect the toes of the shoes? I would love to make this for my wife, but if the toes get damaged, she will end up wrapping this thing around my neck.
Dec 10, 2009. 1:04 PMourmoneypit says:
LOL  from what I read in one of the comments, I think Jayefuu was originally planning to heat-shrink wrap each of the rods.  This might not be a bad idea in order not to scuff the tops of your spouse's shoes.  Maybe some type of foam covering could be had, to be really safe.
The rods under the shoes wouldn't matter, and I think the threading on the rods probably helps to grip the shoes.
Dec 10, 2009. 4:41 AMourmoneypit says:
Excellent!  My daughter could use one of these...maybe she'll get one for Christmas.
Remember, though, if building for a woman who wears girlie-shoes, or men's dress shoes, the rods would have to be closer together as those shoes are thinner.  If building for parties, you could build two, one for thicker shoes, one for thinner shoes.
1-40 of 73next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
236
Author:Jayefuu
I am currently undertaking a PhD at the University of Huddersfield, England, looking at novel techniques in dispersive white light interferometry. Feb - April 2012 I was an artist in residence at I...
more »
