3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Shoe Tower - a free standing, multi-tier floating shoe rack
Step 2Marking and cutting the wood
Picture 2 shows the dimensions of the pieces you will need to end up with.
Draw a line perpendicular to the edge, 600mm from one end of the timber. From this draw a line 15 degrees from the vertical (pic 3), this will give the slant on the shoe tower so it doesn't just fall over forwards. You will need two of these 600mm long bits, with a 15 degree wedge cut of the end of each. They will form the uprights of the shoe tower.
For the feet of the tower, 2 250mm long pieces of wood are required, with the same 15 degree wedge cut out of the end of each. Picture 3 shoes one of the feet drawn onto the wood. Cut along the slanting line then measure 250mm from the pointed end remaining to find the line to be drawn for the next cut.
Once all the pieces have been cut to size, sand off any lightly splintered edges with some medium grade sand paper. I used 120 grit and used the pieces as sanding blocks as I couldn't find mine!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
236
Author:Jayefuu
I am currently undertaking a PhD at the University of Huddersfield, England, looking at novel techniques in dispersive white light interferometry. Feb - April 2012 I was an artist in residence at I...
more »
