loading
Step 2: Cut out the file on the ShopBot
Throw your plywood onto your router table and get to work!
I assume you know how to operate it.
I used a 1/4" upcut end mill. This has left a messy cut that will require some sanding to clean up.
I also thought that I could pick up .25" spline at the local hardware store (turns out I can't) so I routed 1/4" grooves into the frames as well. If you have a tool that will cut appropriately sized grooves this would be a good time to do it, otherwise, skip that step and just cut out the frames.
Cool Instructable. I'm making my own printing shop now. I'd like to know if the organza works well. Can you strecht it tight? it wears out?
Looks crazy :0
About This Instructable
8,542views
38favorites
More by Fortuna Wolf:Screen Print Shop Part 2: Create Platens/Pallets for screen printing on the ShopBot Screen Print Shop Part 1: ShopBot Silk Screen Printing Frames
Add instructable to:
