Short Rage Wireless Music Transmitter
14,004
92
18
Posted
Introduction: Short Rage Wireless Music Transmitter
Now , i am with a short range wireless FM transmitter which can powered through USB. It can take audio signals and transmit it over a short . It's maximum rage is around 100- 150 meters.you can easily listen it over a radio . it's very cheap and easy to build.
Step 1: Fetching Parts
All you need are some common electronic components.
You can buy them at Radio Shack!
1. Transistor BC 548 OR 2N2219a.
2.Capacitors : 1n , 1n , 10p , 10p variable , 1uF electrolytic.
3. Resistors : 2k7 or 2.7 k , 1k , 10k , 10 variable.
4. Inductor : you can make by yourself . 7 turns on 3mm or  6 turns3mm.
5. Battery : 9 volt .
6.  PCB you have to make one or use breadboard.
7. Antenna 10 cm long!
8. Nothing else
Step 2: Circuit Diagram
Here is the simple circuit diagram!
Step 3: PCB - LAYOUT
Here is the PCB layout.
In the next PCB  the red ones are capacitors , green ones are resistors , brown one is variable resistor , white one is transistor , yellow one is inductor and other holes are for power and input and antenna. TO make this PCB at home you have to follow this link : ""https://www.instructables.com/id/DIY-Printed-circuit-board/"".
Step 4: Finished Product
HERE is the finished product!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
18 Comments
this looks great, but it's just one audio channel, right?
Wow, that's was exactly what I want. How far can it transmits. And what's the inductor's inductance. Forgive me if I am disturbing you.
(I think my English isn't well :) )
And don't mess with inductor just make it as said cause i don't remember it!
But I still don't know what is the wire's diametre. You couldn't make it without having this number in mind, right.
Well it's nearly a whole house (not if your house is full of complex radio frequencies and disturbances). It's like 5-10 meters.
hey.. firstly i want to thank you for this amazing build.. i wanted to know how much power does it transmit over the antenna.. because in my country, transmitting over 500mA is considered illegal and i don't wanna break any rules.
thanks..
No worries it's way down that that range may be one or two houses.
What is the USB plug for? it is not on the diagram, it can not be for power as that is 9V.
sorry to bother u.. are we using variable resistor too? if yes, we r varying both resistor and capacitor at a time to set a frequency?
no! the variable resistor is for controlling the volume! to change frequency you have to change the capacitance of the variable capacitor!
