Remove these ads by
Signing UpStep 1Ingredients
First Bob needed to shorten the original 3' wire. Easy enough-just cut it. The wire will have two leads: one smooth and one ridged just like a standard AC cord. Bob wanted his to be very short, and Bob has a lot of experience stripping wires, so if you tend to overstrip wires or cut all the way through accidentally, leave yourself some room. Bob cut his to about an inch on each side (the charger side and the charge plug side). Strip enough from each lead to twist them together, making sure the ridged sections go together and the smooth sections go together. Actually, before twisting, put a section of heat shrink on each lead that will cover the twisted portion and then some. Or just use electrical tape, if you prefer half-assery. Heat up the shrink tubing with a heat gun or a lighter to cover the exposed leads of the shortened wires.
comments
Add Comment
Add Comment
