Step 1: Supplies
You'll need:
* Used shotgun shells (That's kind of a given) Make sure that the plastic is intact and the metal isn't completely rusty, because if it is, then it could break.
* Candle wax. You can use the big blocks of it, or tea lights, or old candles. Whatever you want.
* Double boiler. I use one that is originally meant for melting chocolate, but I find it more useful for this. You can make one by putting a tin can in water in a pot, or you can buy one.
* Some kind of colorant. You can use another candle, or crayons, or that coloring stuff that's meant for candles.
* Candle wick
* X-acto knife
* A stirring utensil
Make sure you put something down for when you are pouring the wax, otherwise it could get everywhere.
Step 2: I'm melting!
Once the wax starts to melt, stir it a bit.
Step 3: Preparing the shells
Your shotgun shells may be dirty. A couple of mine were. You're going to want to make sure they don't have any dirt or anything in them, because that would look bad on the outside of a candle.
Depending on how long the wick you have is, you can either put it in now or wait until after you pour the wax. I'm waiting until after.
Step 4: Once the wax is melted...
It's time to pour it into the shells! Put them on something like tin foil or newspaper, because you are bound to spill at least some wax.
So pour the wax into the shell, up to the very top. You can put your candle wick in now if you haven't already, or you could even wait a little bit longer until it's had some time to set up.
Step 5: Removing the plastic
You can see where I accidentally cut into the wax on the first picture :P
Step 6: And you're done!
I really recommend that you put something under it to catch the wax if/when you burn it, because there's really nothing to keep it from making a mess.
Hmmm... Redneck wedding decorations anyone?
Also, just a couple of tips:
If you use crayons to color it, use Crayola ones, because Roseart ones are kind of weird.
You should put the wick in THEN pour the wax if possible, to avoid any air pockets that may be created when inserting the wick, which is what happened to me :P
After you remove the plastic casing of the shell, there will be plastic at the bottom still. You may want to dip the candle in wax again to cover it up a bit. Don't let that plastic burn, by the way, because these candles burn down pretty fast.
Visit Our Store »
Go Pro Today »
If you put a candle in the freezer for about 1 hour PRIOR TO burning it, the candle will drip less & last longer.
I know that may be impossible with larger candles, but with this size of candle, it should not be a problem.
#2)
Maybe a "plate" that looks like a shotgun shell box to hold the candle(s) AND keep the wax from making a mess on your table or whatever...
#3)
Candle wicks are usually fairly cheap at a craft store, where you can also purchase coloring for candles as well as Crayola Crayons....
Might I suggest having a wick that runs the length of the candle? That way you never have any candle left over without a wick(unless you want candle left overs). not trying to tell you what to do, just offering ideas.
IF, if you buy the wax instead of recycling old candles, there is an additive that you can add to the wax to make them drip less...then there is also a special bulk wax that you can buy that will drip less...
do not ask me how it works, I have no idea HOW it works, I just know that it does.
I like this Ible...4 stars. :)
Any other states you can walk in, and walk out with ammo.
Whats an FID? Been shooting for a while and never heard of that o.O
You might want to cut off the "frilly" ? part on top, since thats where it was folded over on the top of the shell, unfolded they are approx 1cm longer than folded (and loaded :P)
I just wanted to clear that up and make that suggestion, and now I have a reason to collect some shell casings at the range next time I go :D
xD
awesome ible!
Thanks :D
you: "yup"
*10 minutes later*
*BOOM!*
you: "OH CRAP! THE NEIGHBORS ARE ATTACKING"
*inlaws run*
you: *well that's a problem over with. lets go grab dessert"
Way to go, Sunny! :D
"Redneck wedding"...more like shotgun wedding!
Fun idea for otherwise garbage. Though, I see a terrible prank in here somewhere. :)
