Shotgun a Beer with Just Your Thumb
 by noahw
Featured
Learn how to defy the rules of physics and pierce through metal using only your fingertip.  This Instructable shows you how you can shotgun anything in an aluminum can with just your thumb!
Shotgunning liquids has been around for a while.  It's the crude process of poking a hole in the bottom of a can (usually beer) so that you can drink whatever is inside the can way faster than normal.
It's a fun thing to do at a party for sure, but it gets old pretty quick, and there's never anything good lying around to make the hole in the can with.  Using your finger to poke the hole raises things to a super-human level and is an unparalleled party trick for anyone who doesn't know that it's possible.
*****Shotgunning beers with your finger carries an inherent risk of injury and it's possible that your thumb could get cut as it pierces the wall of the can.  While this has never happened to me, or anyone else I've seen try this, my brain tells me that it's certainly something to be aware of.  Pierce responsibly and understand the risks involved of poking holes in metal cans with nothing more then your finger.*****
Step 1: Setup
There are only a few simple tips to shotgunning a beer with your thumb - most are all part of the setup.
Grab any normal aluminum can and position your dominant thumb (I'm a lefty so I use my left thumb) around 1" to 1.5" from the bottom.  The blue line at the bottom of the Pabst Blue Ribbon logo seems to be about the right spot.  Have the mouth of the can that you normally would drink from facing up towards the sky (at 12 o'clock on the top of the can).
Then, hold the can either in your other hand, or use your index and middle fingers to support it along the bottom of the can on the other side so you've got something to push against.  See the photos below.
Think about squeezing the can between your fingers and visualize squashing it like a grape and practice rocking the tip of your thumb so that your finger nail makes a diving motion in towards the wall of the can.
Finger Nail Length
While your length of your fingernail is important for a successful finger shotgun, I don't think that it means everything.  I've seen people with very short nails have success, and people with long nails have them double over and crease.  The ideal length is likely to have around 1/8th of an inch or so of the white colored fingernail extending beyond the cuticle.  That should be enough so that it can make direct contact with the can, but not so long that the nail becomes weak and flexible.
Step 2: The bubble
Reach out with the stronger of your two arms and tilt the top of the can down towards the ground at a slight angle.
The theory of the tilt is to allow the small bubble of air that's in the can to rise to the precise position that your thumb is pressing down on.  This should hopefully make it a bit easier to pierce through the can with your thumb and also keep less of the beer from splashing out when your finger breaches through the can wall.
I don't know too much about can fluid dynamics, and I'm skeptical that it's actually any easier to punch your finger through a can into air than it is to punch it through into a liquid, but hey, we're using finger tips to bust through aluminum here, so it's good to be a believer in anything that might help.
While you're at it, toss some salt over your shoulder.
Step 3: Dent
With the can tilted at a slight angle and your arm stretched out, begin to apply pressure with the tip of your finger to create a small dent in the can.
Step 4: Pierce with thumbnail
Once you've got the dent made, quickly rock over onto your fingertip and engage your thumbnail with the can applying as much pressure as you can possibly exert.
It sometimes takes a few tries to punch through in one spot.  If you're not having good luck putting your thumb through the can, try rotating the can to a new position (don't worry about where the mouth of the can is aimed at this point).
If you still aren't able to pierce through the can, try harder!  Grunt if you have to!  Visualize the strength of 1000 wild animals!
It took me 6 months to finally be able to do it from the first time I saw it done.  I'm no stronger now then I was then, so I think that one's mental approach has a lot to do with success or failure in can puncturing.
Since then, I've seen many first timers pull it off, including many of the people in and around Squid Labs - and our thumbs are weak and delicate from all the typing we do!
Some things that helped me finally be able to break through the wall (literally) were:
  • visualize that there is no can
  • confidence is everything, attack it like you can do it, even if it's your first time
  • try different types of cans - Coca Cola seemed to be the easiest, but I have no quantitative data to support this
  • I didn't go this far, but doing some thumb exercises might help
  • don't cut your finger nail for a few weeks and then try to do it
  • if your nails are too long and are being bent back, cut them down a bit
Step 5: Shotgun the can as you normally would
If you've successfully pierced a hole in the can, then you've earned a special reward - 12 fluid ounces of liquid in your belly delivered in less than 5 seconds!
Raise the hole you just made with your finger to your mouth, pop the top of the can as you would normally shotgun a beer, and gulp down the beer that flows into your mouth as fast as you can.
The hole on top allows air to flow freely in the can, thus eliminating the glug, glug, glug, factor, and lets the beer flow out of the can much faster than it usually would if it were poured normally from the mouth of the can.
Step 6: Shotgun more than just beer!
While drinking beer is a hoot, putting your thumb through cans is so much fun that it's nice to be able to do it even when you don't want a beer.  Maybe your not of legal drinking age yet, maybe you don't like the taste of beer, or maybe you just want to send down a few sodas in less then 30 seconds at the office.
Whatever the reason that you're not shotgunning a beer at this very moment, don't let that stop you from poking a hole through aluminum cans filled with other types of liquid today!
1-40 of 144Next »
i.am.flink says: Jan 28, 2010. 4:15 AM
Ingenuitive, but best saved for flavorless American swill. It would be a horrible waste to do this with a good porter or a highly hopped ale.
poopsmcgee in reply to i.am.flinkSep 21, 2011. 10:49 PM
What "hopped ale" or porter comes in a can, in the U.S.?? Please don't try to use THIS shotgunning instruction web foible as a platform to baselessly disparage american beer. it is as if you are saying "rubber bands are nice and stretchy, but they don't smell enough like bacon.
mrmerino in reply to i.am.flinkAug 30, 2011. 10:00 AM
Wow. Euro much?
imBobertRobert in reply to i.am.flinkJun 9, 2011. 1:41 PM
you started up a riot of comments!
sleebus.jones in reply to i.am.flinkFeb 2, 2010. 7:24 AM
We have a "be nice" comment policy. Please be positive and constructive with your comments or risk being banned from our site.
Apparently you missed this when you posted, so I'm putting it up there again so you can get a clear read at it.
baneat in reply to sleebus.jonesJan 11, 2012. 6:08 PM
How did you miss the intent behind this post? I know it's harder to convey through text but he's not bashing anything but American beer. And American beer is not good. The only american alcohol I've seen imported into the UK has been Jack Daniels, even then our scottish whiskey is better in my opinion. All the good beer is imported from Germany, or brewed in a small scale.
C18H21NO4 in reply to baneatFeb 25, 2010. 11:49 PM
Hey man I agree. I'm American, and very patriotic, but our beer tastes like goat urine.
bendog38 in reply to C18H21NO4Apr 10, 2010. 11:24 AM
 How do you know what goat urine tastes like???
C18H21NO4 in reply to bendog38Apr 10, 2010. 1:14 PM
Things generally taste how they smell, and goat urine does not smell pretty.
MasterMind555 in reply to C18H21NO4Aug 17, 2010. 10:04 AM
That means then blue cheese taste.............?
Turtleholmes in reply to baneatFeb 21, 2010. 9:22 PM
I don't think that it's much to do with 'all American beer is crap', more that people will like the beer they 'grow up with'. That isn't to say that an English drinker will never like American or even German beer, it's just that they're made differently to different tastes.
sleebus.jones in reply to baneatFeb 5, 2010. 7:16 AM
"All the good beer is imported from Germany..."
Didn't anyone ever teach you that when you say something like "all X is Y" that the chances you are are woefully misinformed approaches unity?
cas6767 in reply to sleebus.jonesMar 6, 2010. 12:55 AM
I believe they call that an opinion due to the adjective "good". If he had said all the beer comes from Germany then that would have been misinformation. The beauty of opinions is that they are ALWAYS right like my opinion that you are being facetious and breaking the very rule you claim to be championing in what I'm sure you assume is an extremely clever ploy for attention.
baneat in reply to cas6767Mar 17, 2010. 3:23 PM
I have to ask, do you refer to me?
also, it was an OBVIOUS generalization I made, people. Obviously I don't think all, derp, since I'm well aware some home brewer in Italy can produce far better beer on his small scale than a mass scale factory ever can.
sleebus, Didn't anyone ever teach you that when you say something like "all X is Y" that the chances you are making use of hyperbole?
sensoryhouse in reply to sleebus.jonesFeb 21, 2010. 3:51 AM
 R u people kidding.  Budweiser and PBR are the best beers ever made.  People that wine about how beer needs to be fancy dont drink very much.  People don't pound down 30 packs of "fancy" German beer - but they do go through a couple hundred Buds in a good weekend.  Boom!
K4nyix in reply to sensoryhouseOct 1, 2011. 1:47 PM
You're wrong Sensoryhouse, didn't you ever hear about the Oktoberfest, or Beer Festival in Munich ? there, people drink f*in' good beer, and each "glass" is a pint of 1 Liter. and they don't stop after a few glasses.
In my area, we have traditional local "fancy" beers, and my friends and I drink no less than 4 gallons of it, each, and that each week-end when we drink.
Budweiser DOES, to my opinion, taste like a terrible industrial brew. Although I love the USA and a lot of your stuff, your beer and your cheese won't ever be able to contest with german (or european, since belgian and british beers are so different and pretty good also) beers nor with french cheese.
You cannot say "industrial food is better than traditional food, just because there is more of it". That's just... messed up. Since when MacDonald's is better than a good dinner ? Unless you can't boil water without burning up your house, that's not possible.
marco! in reply to sensoryhouseMay 3, 2010. 7:29 PM
true dat!
TheBestJohn in reply to sensoryhouseFeb 21, 2010. 11:34 PM
 Go Canadian or go home =P
fire bat in reply to TheBestJohnApr 15, 2010. 4:48 PM
 w007 (4/\/4|)14/\/ 823\/\/5|<1 473|-| \/\/1/\/
cas6767 in reply to TheBestJohnMar 6, 2010. 12:46 AM
Moosehead!!!
firestarter1000 in reply to cas6767Jan 9, 2011. 8:36 PM
Damn! straight
JacobsJ192 in reply to TheBestJohnMar 2, 2010. 6:52 AM
I think I'll go home.
sweetpoetaoe in reply to JacobsJ192Aug 6, 2011. 10:06 PM
I've made good beer and im american? andCktoberfest beers are fantastic german style beers, that most anyone that can stand up to some taste can drink down in large quantaties.
"American Beer" or what people think of it is just american style lager, after prohibition the only companies with enough money to keep going were the ones willing to cut corners, mainly using corn and whatnot. Some love it some dont.
Theres other styles Of beer that were invented in america, and Most people still wont taste or have them brought to mind
The California Common, The Black IPA, and most cascade hopped beers.
Most beer styles have their American counterpart as a style of it, like american stouts, such as sierra nevada's.
Just basic knowledge ya'll
BUT this post is just about a method of drinking faster, and its a great method for most who have tried it. Very good party trick!
(and you probably couldnt do this on "fancy" beer anyway , its probably in a bottle)
mettaurlover in reply to sleebus.jonesFeb 4, 2010. 2:52 PM
This comment does not seem to be posted with malicious intent. He is merely stating that American beer has less flavor than other beer, which may, in fact, be true. He is also stating that it is a waste to do something like this with a quality liquid, which is, in fact, true as if it goes through your mouth fast, anything loses its flavor. Therefore, it is not against any of the 'ibles rules.
sleebus.jones in reply to mettaurloverFeb 5, 2010. 6:42 AM
My mistake.  I did not realize that "flavorless American swill" was being positive and constructive.  Apologies.
harley_rly in reply to sleebus.jonesFeb 27, 2010. 7:20 PM
dude its nothin, theres no reason to react like that, so what if European's are proud of their beer
mettaurlover in reply to sleebus.jonesFeb 5, 2010. 8:07 AM
Technically true. We do very little well these days.
gormly in reply to i.am.flinkJan 28, 2010. 6:22 AM
Yea! America Bashing on instructables! Sweet, why'd it take so long?
i.am.flink in reply to gormlyJan 28, 2010. 7:22 AM
Not America bashing, just pointing out that the vast majority of beers brewed in America are good only for washing car tires.
If it tasted good, people would have less interest in consuming so fast that you can't appreciate the flavor. A properly brewed ale or lager will have many distinct features of taste and smell.
Unlike the typical American brew that is best consumed ice cold and quickly so that the taste buds are numbed and the nose has little time register the smell. When in a novel, you read  a phrase similar to, "the bar smelled like stale beer and sawdust," they're describing the smell of budweiser, pabst, coors, olymbia, miller, and the multitude of other cheap brews.
knex_mepalm in reply to i.am.flinkJan 28, 2010. 8:46 PM
What is considered good beer? Here in Australia people can charge $8-$22 for a bottle of beer, we also have cans but bottled is better tasting..
gold03 in reply to knex_mepalmFeb 10, 2010. 9:05 AM
 I think we should try putting our thumbs through bottles! Now that would be a trick!
knex_mepalm in reply to gold03Feb 11, 2010. 1:15 AM
 Hey, Hey, no stealing my party trick, although I might post a video of how to do it soon. It is this awesome trick where I use a hammer about 4-inches I think, don't know about measuring the hammer I'm guessing the top bit. I use the hammer to smash the bottle, seemingly it would explode it leaves a small crack which I blow on and it becomes and hole and I drink out of it.
baneat in reply to knex_mepalmFeb 5, 2010. 6:01 AM
Cans vs bottles is pretty subjective IMO. Drinks to me taste better in ALU cans than glass bottles, I think the can itself imparts a flavour, and I like it. I forget what 8 AUD is, like £4? That's a lot. a pintbottle of good beer goes for roughly £2 over here, and britain's taxed to hell.
knex_mepalm in reply to baneatFeb 7, 2010. 12:39 AM
 Over here we're taxed by wages up to 60% if you earn more than "Euro"600,000
I Love Guns in reply to knex_mepalmFeb 1, 2010. 12:46 AM
Beer in Australia is much more heavily taxed than in America so the beer costs up to twice as much.
Although Americans are only allowed to buy beer at 21 :p i think. (18 in Australia)
i.am.flink in reply to knex_mepalmJan 29, 2010. 1:10 AM
Of the mass-market beers, I was pretty partial to Swan Lager. Also, the Foster's Lager locally-brewed in Australia is worlds better than the swill brewed in Canada for North American distribution.
The times I've been to Perth/Freemantle or Sydney, I've pretty much had those only two, with the exception of a bottle of Emu.
Price does not determine a beer's quality. I wish I had had more time while in Australia.
An example of urine brew that you might be familiar with would be Tiger beer, which I was unfortunate enough to be stuck with in Singapore for quite a spell. All I can recommend about that brew is that it's suitable for brushing your teeth if the local water isn't potable.
R1Ch0 in reply to i.am.flinkJul 17, 2011. 8:44 PM
next time you're in sydney, try a coopers vintage extra strong, it's twice the kick of a normal beer and tastes excellent, although the down side is, it cost $22 AUD for a 6 pack.
veeguy in reply to i.am.flinkJan 31, 2010. 5:17 PM
I was pleasently surprised while living in Kenya. I found 2 excellent brews from Kenya Brewing -Tusker Ale and Pilsner Whitecap beer.  Good warm or cold (I prefer warm).  They also brew a local version of Guiness Stout, but I've never aquired the taste for stout.
knex_mepalm in reply to i.am.flinkJan 29, 2010. 9:57 PM
 Thanks for the info, the Tiger beer works wonders on pen marks on fingers and molotovs (not that I would make one). Nice beer knowledge, Switzerland and Germany produce top quality beer...to me.
Zetheros in reply to i.am.flinkJan 28, 2010. 6:53 PM
"Not America bashing, just pointing out that the vast majority of beers brewed in America are good only for washing car tires."
And poisoning slugs in the backyard ;)
1-40 of 144Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
