Shoulder Tie-Dye Crop Top
481
8
Published
Introduction: Shoulder Tie-Dye Crop Top
This is a very simple tie dye instruction that only requires rubber bands to get the effect. We will be using the bulls eye technique but starting at the shoulders and working our way down!
Step 1: Materials
Crop Top
Rubber Bands
Procion Dye
Bucket
Rubber Gloves
Step 2: Tie Rubber Bands
I started at the shoulder seam and worked my way down until I reached the armpit seam on each side. Make sure to tie tightly so that it will resist the dye.
Put as many or as little rings as you would like! You can also work with different spacing variations to create different effects!
Step 3: Prepare Dye
I already had some leftover dye in a bottle, so that is what I will be using today. Each brand or type of dye will have different preparation instructions, so just follow those to make your dye. (The brand I used is Dharma Trading's Procion dye.)
Step 4: Dip Into Dye Solution
I left the shirt in the dye for about 1-2 minutes. You can leave in less or more time to achieve lighter or darker shades.
Step 5: Ring Out Excess Dye
Once you've gotten most of the liquid out, let sit overnight in plastic bag.
Step 6: Rinse & Remove Rubber Bands
Rinse shirt thoroughly until water runs clear, then remove rubbers and hang to dry!
    • Spotless Contest
      Spotless Contest
    • Slow Cooker Challenge
    This is awesome. Think you really should join the indigo dye contest on Dearlives.com. This work gonna win some awards.
