I experimented a bit and created this woven shrinky dink bracelet. For this project, you will need one sheet of shrinky dink, jump rings, and a clasp.
Remove these ads by
Signing UpStep 1: Cut Pieces
I started by cutting out five squares of shrinky dink, about 2"x2." I have tiny wrists so you may need more squares. I rounded the corners with a paper punch and then cut out lots of thin strips of shrinky dink that were a little shorter than the square.
Next, I used a craft blade to cut strips in the squares. Leave space around the entire edge. This was the tricky part. It's not that easy to cut the strips through the shrinky dink so be careful not to cut yourself. It's also possible to pull down too far and cut all the way down to the end of the square.
Visit Our Store »
Go Pro Today »
Good hunting.
If you are using non-branded shrinky dink (recycled #6), then I'm not sure about the time and temp but I know there are several tutorials on the internet for using this material. I would guess it is similar.
As far as off-gassing, I don't know of any problems. I think if you follow directions you are okay. However, I am definitely not an expert on this material.
I recently saw this on Craft and I'm so happy you shared it with us too. :D
