loading
Step 7: Make room for the USB
Place the usb over the inside of the pieces and mark out its shape. Cut out this shape through the first layer and foam but leave th paper on the outside in tact. do this for the lid asweel but only the for the top part of the USB (the lid). Now remove the cut out section to leave a space where the USB will fit when the pieces are placed together. Glue the two pieces together and the two sides of the lid too.
NOTE: don't cut through outer layer of paper, this will ruin the outside
<p>this looks very cool. i saw the same thing you saw on amazon and i really wanted one, but it would be a lot of fun to just make one for myself.</p>
<p>Hi great design! How strong is it? I feel like if I make one its going to break :/ Does the PVA strengthen it much?</p>
Hey, I think you should modify it so that each &quot;blade&quot; is a usb drive (4 total) <br />Although i don't think they will all fit with the size that you have but, there are smaller ones out there
Yours is the coolest looking USB to make it to the finalists, in my opinion. Nice job, and congrats!
thanks mate, i liked yours too<br>
Sure, and glad you liked it!
that looks awsome, makes a simple work transference into somthing epic
thanks mate<br>
id you use hot glue gun to glue in the usb, or did you use epoxy or super glue? im almost done, just need this one simle question to be answered.
I would reecomend using hot glue like i did, it fills in the spaces around the USB a lot better and the overall strength of the bond isnt too important<br><br>
the acrylic is important. Without it, the foam 'recedes' and you will need to start over.
yep, it would ruin everything
I didn't read all the instructions while i was working on this, so i just went ahead and spray painted it. Whoops... learning new things every day
do you think a USB cap is necessary, or will the foam core board be enough?
it will work either way, you can use the cap to make the top stay on better but it is not needed if you dont want to<br>
did you take the case off the usb before you attached the shariken design to it?
no you dont need to, you just cut to the size of the case. Its up to you.
how thick is the poster board you used
it is 5mm thick poster board<br>
this is awesome. i voted for you in both contest enties.
thanks mate
what kind of paint did u use on the front &amp; back of the shuriken?
i first sealed it with just a pva glue, then coated it in a couple light coats of spray paint, you could also clear coat it to make it shiny<br><br>
hey coul you do this with just the insides of the usb? oFTo
yeah, just cut out a little less to make the circuit board fit snug to avoid damage<br><br>
Cool beans!
thanks mate, please vote<br>
Thats just awesum. My sis would love it... nin-star headphone holder anyone?
That would be amazing. Nin-Star Headphone holder. Yeah!
thank you very much and dont forget to vote<br>
Awesome ible! Ima full ninja fan anyway. But i don't think i'd throw this one.<br>Great Work!!
The amount you Rule is beyond words good Sir :D <br> <br>I wnated to use Fimo, but your design is better <br> <br>Thank you for sharing :)
Thanks for your comment and please vote for this instructable
About This Instructable
384,837views
120favorites
License:
More by eyefail:Shuriken USB Collapsible Gaming Cockpit
Add instructable to:
