You will need:
.25mm wire available from hobby/model stores. (I only used one colour, but you will find it extremely useful to use three)
And you are advised to have:
A positionable magnifying glass
A thin-point soldering iron.
As long as you are careful and take your time, this modification is not particularly difficult.
Remove these ads by
Signing UpStep 1Remove the plastic body of the camera
1) Remove the 5 obvious screws from the case.
2) Slide your fingernail gently down the seem of the camera to snap the clips off. The back section of
the camera body will come away.
3) Remove the small metal rod that forms part of the camera strap anchor, and save it for reassembly.
4) Remove the single right side screw, and remove the front section.
Be sure not to accidentally touch the flash capacitor contacts, which will give a nasty shock!
![Hack Your Vivitar Ultra Wide and Slim Camera [Updated]](http://img.instructables.com/files/deriv/FVW/UCVD/G9GQEV1L/FVWUCVDG9GQEV1L.SQUARE.jpg)
i have a fuji s1500 i i want to do this i have the camera open already but how can i figure out where to solder my cables ( which one is ground, focus, shutter )please help i know this is old but hopefully you still there
I'll just have to increase it's mass (well, it will be attached to a frame and then bolted to a car) :P I'm on the fence on how I'm going to go about it -- Tool and I are both working on solutions for time lapse photography. His prototype is 100% mechanical, I'm working on one that's a little more electrical :P
My camera (Olympus SP-350) is lacking a remote switch too but regretfully I'm definitely not "that brave" to open it.
I'll have go mechanical, or use self timer ....
