Shutter Upcycled (repurposed) into Magazine Rack by My Repurposed Life
Featured
Shutters or bi-fold doors are easily found at the curb or thrift stores.  This project was made from a bi-fold door that I cut in half.
Step 1: Remove every other slat
You will need to remove every other slat. You can do this by using a claw hammer to break the slat you're removing. I used my Dremel Max to flush cut every other slat.
Step 2: Sand the cut slat.
If you use a hammer to remove every other slat, fill the empty holes with some spackling or wood putty. Because I used the Dremel Saw Max to flush cut my slats, I sanded the pieces smooth.
Step 3: What your shutter should look like
After removing your slats, you can see that you will easily have room to hang your magazines. Tip: I save my removed slats to use as paint stirrers.
Step 4: Prime your shutter
I used a paint sprayer to get a great (easy) coverage.  If you don't have a paint sprayer, you can use spray paint. Painting by hand is another option. Be sure to check the opposite side so that you don't get drips and runs.
Step 5: Paint your magazine holder with a topcoat
I used a can of spray paint for the topcoat.  Again, you can use a paint sprayer or paint by hand, being careful to not get any runs or drips.
Step 6: Embellish your magazine rack
I used a vinyl cutter to add a decorative swirl. You can use a variety of embellishments, including wood, or some old decorative hardware. There is a definite right side and wrong side to hang your magazines.  Be sure to test to see which way you want your magazines to hang.
dadean04 says: Jun 11, 2012. 11:34 AM
Love it! Unfortunately, I just gave away my old shutters ;(
Loopstyle says: Mar 14, 2012. 5:34 AM
Awesome idea! Like it!
timwikander says: Feb 28, 2012. 7:41 PM
Clever! I think my dwell subscription would do quite well on one of these :).
My Repurposed Life (author) says: Feb 29, 2012. 4:59 AM
Thank you very much.
Penolopy Bulnick says: Feb 28, 2012. 10:16 AM
This is so cute and very handy to have! Awesome idea!
My Repurposed Life (author) says: Feb 28, 2012. 11:10 AM
Thanks so much! I like quick and easy projects ever now and again!
gail
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
