3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Signet Ring
Signet Ring
This instructable will guide you through the steps to create your own signet ring. My end goal was to cast one out of metal myself. I do not at this time have the means or the ready cash to gain the means to acquire the tools necessary. So, I decided to do the next best thing and create one out of other materials. I am overall pleased with the final product. I am planing to design more seals with which to seal my letters. I hope you enjoy.
-MagicFAP
Step 1Setup the wax for carving
I did not have good wax for carving so i decided to make a block myself. I first drew a pattern and then cut out a metal form to hold the wax. I then melted a candle into the form.
12 comments
Mar 1, 2012. 6:28 PMElectricUmbrella says:
Would carving the symbol into resin be different from carving it in wax? (being a harder material.)
Dec 7, 2011. 2:21 PMacoleman3 says:
a better wax for this might be the french wax from http://www.letterseals.com/french-sealing-wax.html
it's a hard wax and would be more durable and less brittle then candle wax. sure, the candle wax may have worked....but this wax would work better.
Dec 7, 2011. 2:25 PMacoleman3 says:
another idea would be to find the oriental seal blanks (http://www.willsquills.com.au/ChineseSealStones.html), carve your seal in the end, cut it off 1/4 to 3/8 of an in, then epoxy it into your ring. that is if epoxy has any grab on soap stone.
Nov 1, 2009. 6:00 PMrussian5 says:
My coat of arms is too detailed to make like this...
Dec 21, 2010. 11:06 AMlunius says:
I may have a solution for that one..
Heat the tip of a needle on a candle flame and, using a rubber glove, use the needle to draw in the symbol. The heat of the needle tip may help to melt the wax a bit and decrease resistance..
Jul 16, 2010. 11:52 PMdawsonj says:
magic... fap?
Dec 21, 2010. 11:02 AMlunius says:
LMAO! I noticed that too!
Mar 18, 2010. 5:29 PMCoranu says:
 All I have to add is, invest in proper sealing wax. It's an entirely different structure, and makes opening the letters afterwards MUCH easier. Plus, there's no seepage into the paper itself. Much nicer over all. Barnes and Noble definitely has some, and a local hobby shop with a decent stationery section should have it as well.
Dec 10, 2009. 1:44 PMwizardorion says:
Just wondering what kind of wax you used?
Sep 17, 2009. 10:56 AMlittlebastard says:
Whats that symbol?
Sep 10, 2009. 2:09 AMWard_Nox says:
not bad just fyi the guy who did the lght up green lantern ring exsplains how to cast with metal and resin the resin might be a way to do a ring for you that would be cheaper and fairly easy
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Magicfap
