3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Silent Annoyatron
Silent Annoyatron
You might think that a silent version of ThinkGeek's Annoyatron would be pointless. But you'd be wrong, because it's actually a whole new way to wage psychological warfare on your officemates. Just plug it in to their computer's microphone or line in connection, and send the Annoyatron's noises through the computer's sound system!
Alternatively, you could use some kind of amplifier / speaker to simply make it louder (though this would also make it larger). You could even plug it into the audio input on a Personal Soundtrack Shirt to have an Annoyatron that goes wherever you do.
Step 1What you Need
What you Need
What you'll need for this hack:
- 1x Annoyatron
- 2x wires (preferably red and black, but any two wires will do, so long as they're insulated)
- 1x 3.5mm headphone plug (either from an electronics store, or salvaged from dead headphones/speakers/etc)
- Soldering iron and solder, or conductive glue (not pictured)
The wires should be long enough to give you enough cable to go from the microphone or line in socket on the back of your victim's computer to the spot on the back of the case where you intend to hide the annoyatron (using its built-in magnet).
I would recommend using a soldering iron and solder, so long as you have a fine enough tip to get between the other components to where you need to solder, as conductive glue (at least, the stuff I have - linked) takes a while to set, and you need to hold the wires in place while it sets. I used a ColdHeat soldering iron with conical tip.
12 comments
Jul 15, 2010. 10:12 AMbricker says:
sneaky little thing....
Apr 5, 2009. 11:23 AMhg341 says:
well i like this but i would install it inside the case on the mb or on the sound card
Apr 11, 2009. 9:29 PMmusicninja17 says:
Or you could connect it on the inside of the compter case to the line-in wires........that would take forever to find :D
Apr 12, 2009. 12:32 PMhg341 says:
i said inside the case..... and all you have to do is find the pins from the input jack and its really not that hard
Feb 17, 2010. 3:46 PMArano says:
when you put it inside the case i suggest you should use the computer as energysource instead of the battery to increase the time the annoyatron works
Feb 21, 2010. 10:47 AMhg341 says:
yea that wount be hard
Apr 12, 2009. 7:20 PMmusicninja17 says:
sorry i didnt see the word "computer" there..... and by forever to find I meant the person that is being pranked by the annoyotron......
Apr 13, 2009. 10:56 AMhg341 says:
oh I see what you meanand its ok
haha most ppl I know would just give up
Aug 4, 2009. 11:16 AMstruckbyanarrow says:
here is some pictures of mine i used a 1/8 in. plug from the shack... 5/5
Apr 6, 2009. 5:36 PMconrad2468 says:
If you did that to me the first place I would look would be the audio jack......great idea, but you need to make it stealth-ier..... ****
Apr 5, 2009. 8:33 AMyourcat says:
Good idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Maximinus
