A monofin is what will make your tail really move through the water. This fin will go inside the "fluke" of your tail. It will be sandwiched between two layers of silicone and will be where you put your feet. The monofin you pick can change the overall effect your tail has moving through the water. You will want to decide where you will be swimming most. If you will only be swimming in pools, you can use smaller, softer monofins. If you want to swim in the ocean, against ocean currents, you will need a much stronger fin.
Pictured (from left to right): FINIS Trainer, FINIS Shooter, FINIS Foil.
FINIS makes many high quality monofins. They come in different kinds of rubbers, plastics and fiberglass.
- The FINIS Foil is a great beginner monofin.
It is made entirely of rubber and has a smaller blade. It is softer and not recommended for ocean swimming. It is great for maneuverability, flips and turns. Not speed or power. Using this fin will give your tail a very soft and "floppy" fluke. *The heel straps are known for being thin with the potential of snapping.
- The FINIS Wave/Rapid is a step up.
They are made from a harder plastic with a larger blade than the Foil. They can easily be cut to shape with sharp scissors or a dremel tool. The ridges can sometimes pose a problem of being visible. You can sand them down a bit, however it will decrease the strength of your fin. This monofin provides more power than the Foil, while still allowing for maneuverability.
- The FINIS Shooter and Trainer have fiberglass blades.
The FINIS Shooter has a shorter blade than the Trainer. These blades are much stiffer than the previous mentioned monofins. They provide for great speed and power, but are best for different types of kicks. The Shooter is great for fast, small kicks for butterfly stroke. The Trainer is good for larger kicks. Both provide decent maneuverability. The Shooter will give a "floppier" look to the fluke. The Trainer will provide more stiffness.
- The FINIS Competitor is the monofin often used by professional freedivers.
It has a large fiberglass blade meant for ocean swimming. It provides little maneuverability, but the greatest speed and power. It requires a great deal of muscle to really master this fin. It will give your tail a very stiff fluke. It is also the most expensive monofin listed here.
My personal favorite is the Triton, Hydra and Minos monofin by a French company.
- They can be quite difficult to source in the US. The shipping often costing more than the fin itself. They have a large Polypropylene blade with Polypropylene stiffeners on each side. The blade itself is smooth and slightly transparent, lending itself well to a silicone tail. It provides wonderful propulsion and maneuverability.
There are many monofins to choose from!
You may want to modify your monofin's shape. If you do, be sure you do not cut the monofin into a point! Sharp corners can cause the fin to snap. More info on cutting a monofin can be found here.
