Introduction: Silicone Coating Your Tweezers
Picture of Silicone Coating Your Tweezers
People who keep snakes, lizards, spiders and scorpions often use rubber-tipped tweezers to handle their pets, or their prey. The rubber tips allow a good grip and prevent damage. But they tend to wear quite a bit, especially if like me, you take them into the field. This is an easy and cheap method to coat the tips of your tweezers again, this time with silicone.
Step 1: Materials
Picture of Materials
You will need your old tweezers, silicone kit, and some petroleum based thinner. The color of your tips will be that of the silicone you use.
Before you start, remove the old rubber tips from your tweezers, and clean and de-grease the tips.
Step 2: Mixing Your Silicone Soup
Picture of Mixing Your Silicone Soup
Mix about half thinner, half silicone into a small container. Mix by shaking vigorously. No, shake a bit longer. No, even longer than that. The silicone has to have the thickness of liquid yoghurt, and be without any lumps. So keep shaking ;)
NOTE: The tips of your tweezers will be coated by dipping them into this mixture, so if you want e.g. 4cm of the tips coated, your container should be at least 4cm deep with the mixture.
Step 3: Dip Your Tweezers
Picture of Dip Your Tweezers
Once your silicone solution looks good, you can dip the cleaned and de-greased tips of your tweezers into the mixture. Make sure they don't touch the sides of the container! Keep the tweezers with the tips down at all times!
Once dipped, you can hang them to dry. It usually takes several hours, I usually leave them to dry overnight.
NOTE: if the solution is too thin, you can leave the tweezers to dry for an hour, and then dip them again. That way you will still have a nice thick layer of silicone.
Step 4: Done!
Picture of Done!
Congratulations! Nice new tips! Ready to wrangle some small critter without hurting it.
Battlespeed (author)2014-12-20
Should make the tweezer tips less prone to transmit heat. (Silicone is commonly used for this purpose.)
Also, I'd think brushing it on the upper part would improve the grip, and even make them more comfortable for prolonged use. A couple of coats would improve the durability of the grip.
mmanca1 (author)2014-10-19
Very nice and useful idea
hooch_is82 (author)2014-09-28
It's a good idea. great tip. Will make it easier when making models or anything with small parts
Raitis (author)2014-09-23
Nice, thanks! Is the coating conductive? Could probably use that for electronics as well.
Ariev (author)Raitis2014-09-23
I would hesitate to use it as an insulator, as the resulting coating is rather soft, and probably more fragile than is necessary to safely insulate wires.
Raitis (author)Ariev2014-09-24
Oh no, I didn't have any intention of insulating wire with that, just thought that with this coating I could probably make regular tweezers antistatic. (:
JM1999 (author)Raitis2014-09-23
Silicone isn't conductive but if it gets a small tear in it you wouldn't be too happy!
Great job, this outta get better grip on those pesky splinters I keep getting...
rimar2000 (author)2014-09-23
Very useful info, thanks for sharing.
gravityisweak (author)2014-09-23
How about plasti dipping the tips?
Ariev (author)gravityisweak2014-09-23
Sure, there are ready made rubber dipping products on the market. This is just cheaper, and most people will have all necessary ingredients already.
MsSweetSatisfaction (author)2014-09-23
Nice fix, especially one that's going to save SO much money! You should enter it into our Fix It contest. Thanks for sharing!
Thanks for the tip! I entered in the contest.
Makersauce (author)2014-09-23
awesome man! could save us quite a lot of money and lives lol
About This Instructable
8,378views
88favorites
License:
More by Ariev:Silicone coating your tweezers
Add instructable to:
