3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Silicone headphones (earbuds / ear-buds) for koss plug
I love podcasts and audiobooks. They trump radio since I can listen to them anytime I like, fast forward past ads and share them with friends. Librivox provides hours of free entertainment courtesy of the classics. Yes, this means that Voltaire's Candide is ready at 6am on a Saturday while repainting a bedroom!
I don't have a car, by choice. My neighborhood has stores nearby and bus lines that make it perfect for walking or public transit. Ever since I can remember, I've loved to take long walks around my neighborhood and explore the world at a human pace. Portable audio was the perfect match! The side streets are quiet, with minimal car traffic. However, I still need to filter out the noise around me especially on buses, the metro and noisy sidewalks next to busy streets. Cranking up the volume is one option, but not healthy for ears that need to last a lifetime.
A few years ago, I discovered Koss Plug headphones that insert an expanding foam plug within the ear canal, like the safety earplugs I used when mowing lawns. The first time I tried them out, they fit perfectly into my ear and blotted out even the loudest noises. Rumbling city buses and poorly tuned cars no longer interrupted my news feeds, science articles and audiobooks.
The plugs performed well for the first five or six times, but changed their resilience over time. The slow recovery property or memory of the foam seemed to fade, so it became harder to position them inside my ear at the depth required to block sound. They seemed to lose springiness too. If I turned my head, one edge of the foam edge would deform and block the center channel, silencing one of my ears until the foam spring back. During winter, the edges of my hat or hood covering my ears would would have the same effect, tilting the plug inside my ear and blocking the channel. Plus, the plugs would eventually get dirty from earwax - yuck!
I remembered further back to a pair of silicone earplugs, EarPlanes, that worked much better than the foam safety earplugs. They were made from a hollow silicone tube with a cylindrical portion on one end and flanges at the other. The central channel had a ceramic element for equalizing air pressure. The directions suggest placing the flanges inside the ear canal, but they worked better by using the other tapered cylindrical end.
Maybe someone had already combined these ideas together. Jabra headsets come close, but don't place the silicone tube far enough in the ear. Other instructables teaches how to modify earplugs with the same expanding earplug foam as the Koss design.
http://www.instructables.com/id/Improve-Your-In-Ear-Monitors/
http://www.instructables.com/id/Poor-Man-Noise-Canceling-EarBud-Headphones/
http://www.instructables.com/id/Create_the_Ultimate_Noise_Cancelling_Earphones/
Since the silicone material in EarPlanes doesn't compress, they wouldn't deform and close up when I turned my head or wore a hat. A search for silicone ear plugs turned up many designs for earbuds described as "in-ear," but they don't extend far enough into the ear to block sound adequately. Plus, it seems that my ears are smaller than most of the designs out there, so they keep falling out.
OK, enough yakking! Time to make earplugs!
####Steps ###
collect supplies
remove plugs
remove ink tubes from pens
tape ink tubes to container
apply silicone to ink tubes
remove cured silicone tubes
trim silicone tubes
Step 1Collect supplies
Collect supplies
You'll need at least 24 hours to complete this project, and 1 hour of active effort.
###### materials ######
$10 - Koss Plug ear buds / headphones
$5 - silicone rubber adhesive
$3 - caulk gun
$1 - 4x ballpoint pens (bic works great)
$1 - tape
container (soda can, plastic yogurt tub or coffee can)
scissors
pliers
Leftover silicone adhesive will be enough, you won't need a full tube. Some stores sell smaller tubes shaped like a toothpaste tube, so you can skip the caulk gun. the ballpoint pens are only used as templates for forming the inner channel of the silicone tubes, so you can keep using them after this project.
4 comments
Feb 1, 2010. 7:46 PMjongscx says:
This type of silicone vulcanizes in a way that seeps acetic acid/vinegar.  There's the Platinum-based stuff, but it's a lot more expensive.
Feb 1, 2010. 5:11 PMgrannyjones says:
i would think that food-grade or aquarium silicone is most likely to be appropriate, being purportedly less toxic.  One would be careful to follow instructions precisely regarding curing time.  I need to try this, too; but one side would have to funnel sound into the mike of my BTE hearing aid. ( I opted to omit the telecoil because I hate sound distortion.)  Still trying to figure out a makeshift boot without harming my expensive instrument.  They just don't make what I need for my equipment--not for under a few hundred bucks.
Feb 1, 2010. 4:17 PMSystemZERO says:
I'm wondering about the health issues of putting industrial grade silicone in your ear canals. I used to work with silicone, and it is nasty stuff.
Feb 1, 2010. 5:09 AMrimar2000 says:
This is an excellent method, I made some time ago earplugs using plain soap for mold, and they gave me very good result.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Squirreled
