3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Silkscreen Print with Vinyl
Step 2Staple the screen
staple the screen
After you have one side completed, start in on the side opposite. Start with the center of the opposite side. Pull the screen very tight until you have the staple in the wood then let go after you staple. Next do the top corner and bottom corner. The next staples go into the center of the top and bottom gaps. When you have the side pretty much done, you can go back and put a diagonal one in the gaps. Tightness is important.
Next do either the top end or the bottom end. Same technique as above. When you are done, the screen should be uniformly tight and taught as a drum head.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:connors934
