Simple 12 Volt to 240 Volt Mini Inverter Using MOSFET & 2N2222 Transistor
Published
Introduction: Simple 12 Volt to 240 Volt Mini Inverter Using MOSFET & 2N2222 Transistor
About: I like making new things from trash. For more cool content please subscribe to my YouTube channel @ https://goo.gl/BHxFf7
In this tutorial i will show you how to make a Simple 12 volt to 240 volt mini Inverter using MOSFET & 2N2222 Transistor
To build your own 12 volt to 240 volt mini Inverter using MOSFET & 2N2222 Transistor you can watch the video embedded in this step or continue reading.
Step 1: Parts List
***Parts List***
  • 2 * IRF540 MOSFET
  • 2 * 470 Ohm
  • 2 * 2N2222
  • 2 * 4.7uF/50v
  • 2 * 3.3k Ohm
  • 2 * Heat Sink
  • 1 * 2 & 3 Pin Terminal Block
  • 1 * 1.2k Ohm
  • 1 * RED Led
  • 1 * Bulb Holder
  • 1 * 240v to 12-0-12V 5amp Transformer
***Purchase or Affiliate Links***
Banggood
AliExpress
Amazon USA & UK
Amazon India
Note: all the purchase links provided are affiliate links
If you wish to support my work then you can do by using my affiliate links given below, this way i get small commission for your purchases.
Bangood - https://goo.gl/ZUhRmV
AliExpress - https://goo.gl/jioyhV
Amazon USA - http://amzn.to/2u7ztbP
Amazon UK - http://amzn.to/2wu4nYP
Amazon India - http://amzn.to/2hroLHz
Step 2: Circuit Diagram
Construct the circuit according to the circuit diagram.
Calculation :
Let's see the calculation
The frequency is given as
f = 1/T
or
f = 1/1.38*R*C
where : from our circuit diagram R3=R4=R & C1=C2=C
In my country the standard frequency is 50Hz
So considering that our f = 50Hz
since i have two spare electrolytic 4.7uF/50v, i have chosen C1 & C2 to be 4.7uF
Now we are left with R3 & R4 calculation
Substituting all the values that we know, we get
R = 1 / 1.38 * 50 * 4.7u
Hence R = 3083 = 3k
Considering the nearest available resistor value i have chosen 3.3k ohm
So our values are
R3=R4=3.3k Ohm
C1=C2=4.7uF
f = 50Hz
You can watch the construction & testing of the circuit in the video embedded in the first step or you can also watch it by clicking here
Thank you for reading !!!
Please subscribe to my YouTube Channel for more video content by clicking here
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
