Simple 12V Cordless Drill Hack!!!!!
Give your 12V battery drill some real GRUNT!!!!!
YAY! Almost finished my scooter for Project: Underglow. (Will be published soon) I just need to drill a hole here...(grabs battery drill, clips in battery)...5mm bit......about there......and drill. Bugger. Battery flat. AGAIN. I was fed up. It was 2:30 in the morning. So I did this real quick hack to my drill. AND took photos :) just to show you'se mob.
It basically involves tapping into the 12V input to the speed controller, which would normally be fed by the crappy battery they give you. Sure, you can re-pack them with some big Ni-MH's, but I'm poor at the moment (around A$95 to repack a pack here in oz). So I decided to just hook it to a big SLA, which will give me some juicy current.
Pros:
*Drill for longer (higher capacity battery)
*more torque (SLA has higher surge current capacity)
*Lighter (only lifting an 800 gram drill, not an 800 gram drill AND a 2.2Kg battery)
Cons:
*Cord hanging out back (I can live with that)
So lets get started!!!!!
Step 1Stuff you will need
Stuff you will need
You will need:
*A drill
*An SLA
*Some fat cable
*Terminal block (optional)
28 comments
Nov 26, 2011. 10:02 AManthonyfca says:
great idea this, I travel a lot by car, and need everything running off 12v where mains 220v etc is never available. I'll use a big "booster" sealed lead acid battery which I can recharge from the alternator when travelling.
The SLA (Sealed Lead Acid?) looks exactly like the type used in some computer uninteruptible power supplies (UPSs)
Thanks for this, just brilliant for what I need - and from some time in the past. Nice .
Anthony
Dec 12, 2011. 3:32 PMabstracted says:
i gutted an old battery and wired it to a mail car lighter socket.....works great....great idea btw
May 22, 2011. 12:43 AMcleardanny says:
i'm a bit late here but now it's not wirreles anymore so you can use a 220 v or 120 v drill.
This is good for a place where is no electricity if you have it's not usefull .
Apr 10, 2011. 1:18 AMAndale_The_Great says:
tried with a car battery sitting at 12.6 volts and the wires just get hot with no movement from drill. mine is a dewalt tho
Jun 15, 2008. 7:26 PMcampingfreak says:
is an sla a car battery???? sure looks likeit
Jun 15, 2008. 10:31 PMCameronSS says:
Not usually. SLA means Sealed Lead-Acid, meaning that it doesn't have vent ports, and can be tipped in any direction. Car batteries are more often "floodies," which are also lead-acid, but have removable vent caps to allow you to replenish the electrolyte. This cap doesn't seal perfectly, though, and the case isn't completely filled, so they have to stay upright.
Jun 22, 2008. 10:52 AMDerin says:
maintenance free car batteries are also sla
Nov 3, 2010. 8:57 AMLee Wilkerson says:
Not always. SLA has no vents. Most maintenance-free batteries have vents which can only be opened with a large screwdriver or pry bar.
~/Lee
Jun 16, 2008. 3:51 AMPKM says:
Also remember car batteries are high current but low capacity and don't like being drained, but the SLA shown is probably a more deep cycle than a car battery so can happily be drained and recharged a number of times.
Jun 22, 2008. 10:54 AMDerin says:
then keep the engine running that works bcz of a magical device called an alternator
Jun 22, 2008. 1:36 PMPKM says:
Well if you have to have your car there it's not quite as portable, is it? I thought the point was that you could still have a more or less portable drill but a better battery life than the original. I know running the car engine would keep the battery topped up, but then you might as well run it off the cigarette lighter socket. The sarcasm is unnecessary.
Jun 23, 2008. 8:30 AMDerin says:
A car is portable.But good idea on the lighter socket,you would at least be safe ps i wasnt sarcastic pss the idea would be useful when you work inside the car
Jun 29, 2008. 12:13 AMDerin says:
think:being spun around on the "trigger" belt
Apr 23, 2010. 6:42 PMmapmaker54 says:
I did as instructed but I don't have enough power from a 12 volt 7 amp lead acid battery.  What battery did  you use?
Aug 31, 2010. 9:01 AMEv says:
Mapmaker, Are you wiring a 12v drill? This won't do much for an 18v tool!
Feb 3, 2010. 10:53 PMYerboogieman says:
Damn, my drill holds the battery in the handle so it is hard to access the terminals.
Oct 3, 2009. 6:33 AMmaysound says:
This project gave me an idea for an old drill I had lying around. I connected a 10 foot cable with a cig. lighter plug on the end. I have several of those portable 12 volt power packs here and can use the drill with one of those. The power packs are basically a SLA battery in a case with a lighter socket and a power inverter AC outlet. Works great for hours. Thanks for the idea.
Oct 23, 2008. 1:25 AMthermoelectric says:
Do you get your SLA's from Jaycar because they have the Diamec ones (they have the same one U used so I guess u did) in their catalouge here
Jul 24, 2008. 4:56 PMtrogabird says:
don't use terminal block but get crimp on terminals from parts house. Battery will have to replace sometime. I did my 2 million CP light like this after battery died. Pulled high beam out of mu truck light ;1989 and rigged it in light. This gave me a charger and charger plugin for the battery. had to remove the resistor or what ever it was for old battery was only 6 volt. Solder the charger plugin into both your wires going to drill. The charger was a 12 volt power pack 1 amp type. works great. If you have a 12 volt charger that fits lighter plug in car, charge it as you drive. I carry my battery in an arm sling I happened to have. No worries about taking off and forgetting to pick up the battery.
Jun 16, 2008. 5:15 AMBubbler says:
My old cheap and nasty 12V drill had a flat battery when I wanted to use it a few days back. I decided to clean up the shed and found a battery powered tool kit that has a sander, circular saw, torch and jigsaw with it. None of these work successfully as the two 14.5 batteries are no longer sufficient and die almost immediately. I tried one of these batteries in my drill, and it almost fitted, only the clips did not match. Pulling the trigger, the drill burst into life, and so I gaff taped the battery on. I used it a lot to do 20 meters of fencing over the weekend, and it goes really well. I now have three batteries and no excuse for a dead drill.
Jun 15, 2008. 6:23 PMej37 says:
Your innovation is impressive. Great idea Fudge!
Jun 15, 2008. 8:07 PMTrans_Am says:
SLA stands for sealed lead-acid. I had to search for it on wikipedia.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Da_Fudge
I like electronics.
