3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple 12v compact fluorescent tube ballast/inverter only eight components! updated!
This is an inverter that can drive any 8 to 25watt compact fluorescent tube with a 11to 15v input.
It consists of a ferrite core,tip3055 transistor,two resistors,two capacitors.
i use tubes out of old energy savers.
Step 1Parts required
Parts required
You will need:
tip3055 transistor
180R resister(1w)
47R resistor (1w)
16v 100uf capacitor (electrolytic)
100n green cap (brown inductively wound will work)
toroid ferrite core (4-5cm x1cm)
heat sink (essential)
3 meter 0.7mm winding wire(0.6-0.8)
5 meter 0.5mm winding wire
old energy saver bulb.
power supply/battery of your choice.
24 comments
Feb 22, 2012. 3:37 AMrobi_ncc says:
Can I use a non-polarized capacitor in between fluorescent tubes two loops like the circuit diagram in my comment?
And can I use 40W fluorescent tube in this circuit?
And as the power source is 12v battery so, if the battery discharge around 10.8v then the fluorescent tube's brightness well dimmer then how long did fluorescent tube will light brightly. Because I use two compact
fluorescent tubes before and both of them did not light brightly even battery full charge.
And sorry for editing your circuit diagram.
Oct 9, 2009. 1:34 PMjonathanmlang says:
I've built this circuit and there is a better way of heating the filaments. when you have wound the secondary, twist a center tap and then put on another 35 turns. put the start of the winding to one filament of the tube, the center tap to one end of the other filament and the end of the winding to the other end of the filament. You no longer need the switch start because this will start the tube reliably and automatically. This works because I have tried it.
And don't forget, never run without a tube because it burns out the transistor in seconds!
Sep 29, 2011. 6:50 PMlam says:
Hi jonathanmlang .
Could you post your schema here ??? for people easy to see and to learn. Thank you
Oct 12, 2011. 2:42 PMjonathanmlang says:
Well since its been such a while ago since I posted that comment I have made some massive improvements to this inverter. If you decide to make it wind the primary starting from the bottom to top then again after the center tap. This one will start the lamp softly and looks like a professional rapid-start during starting.
Oct 12, 2011. 7:19 PMlam says:
Dear Jonathanmlang.
First thank you so much for your time to post your diagram schema ,But unfortunatery the picture is too blearing,not clear to see.Could you re-post an other..
Kind regards
Oct 17, 2011. 10:22 AMjonathanmlang says:
I uploaded the image much larger than the one above but instructables shrunk it down! I have made an instructable of how to make this inverter so you can see it better.
Oct 17, 2011. 2:04 PMlam says:
Thank you so much Jonathanmlang.
Kind regads
Feb 10, 2011. 7:05 AMred eyes says:
make this diagram easier
Apr 9, 2010. 7:39 PMflying pie says:
i want to make it smaller in size so i can put it in the case of the old cfl and is there a way to make it for  a 38w  cfl
Feb 6, 2010. 6:01 PMjunits15 says:
i think you mean 108 Ohms and 47 Ohms
Dec 3, 2009. 7:04 AMchub2 says:
We don't get the winding wires in our place so I will have to get the wires from old transformers. so it will be difficult to know the diameter of the wires.
will it be ok to use any type of winding wires without knowing the diameter?
Thanks
Chuba
Jan 31, 2010. 7:19 AMjunits15 says:
as long as they are close (within 4-5 AWG) it "should"  work, theoreticly, the thickness itsnt terribly important as long as the rest of the circuit is correct.  were do you live, that you cant get magnet wire?
Jan 31, 2010. 6:47 AMjunits15 says:
i have two transistors, a 3055 and a 2n3055, the 2n3055 is huge (100+ watts) the regular 3055 is about 65 watts.  will either of them work or just the regular one?
Sep 23, 2009. 6:08 AMjiraya-sama says:
Hi, i'm italian, sorry for my bad english, i have buy a 8 W 56 Volt 0.145 A actinic neon, how i can modify this circuit for this neon??? Thanks
Jul 22, 2009. 5:44 PMVadimS says:
Um the output is ac not dc therefore the wear would be even.
Jul 6, 2009. 9:40 AMmattccc says:
is this baised on a flyback transformer driver?
May 4, 2009. 10:41 PMbilalinpk says:
please post a clear diagram i shall be very thankful to you..
May 14, 2009. 6:29 AMmgalyean says:
Is that -12V supposed to 'ground'?
Otherwise it looks like it requires 24VDC to operate (+12-12=24).
Do you have any ballpark for efficiency? How warm does the circuit get? Too hot to touch? (the transistor and any resistors would be the key components to monitor). The hotter they run, the less efficient the circuit. Unless it is also considered a mini space heater.
Thanks for the ible, it will be useful renovating boats and campers.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:12V
