Step 4Create a pcb to mount it on.
but watch out because the jump wires may be confusing!
now find the lamp you put aside and connect the base terminals
to the output wires and test it and then you are finished!
Could you post your schema here ??? for people easy to see and to learn. Thank you
First thank you so much for your time to post your diagram schema ,But unfortunatery the picture is too blearing,not clear to see.Could you re-post an other..
Kind regards
Kind regads
Otherwise it looks like it requires 24VDC to operate (+12-12=24).
Do you have any ballpark for efficiency? How warm does the circuit get? Too hot to touch? (the transistor and any resistors would be the key components to monitor). The hotter they run, the less efficient the circuit. Unless it is also considered a mini space heater.
Thanks for the ible, it will be useful renovating boats and campers.
