Easy Arduino Stopwatch
5,142
20
Posted in TechnologyArduino
Introduction: Easy Arduino Stopwatch
Hello. I will explain how did i make this simple stopwatch.
Step 1: Connections
Only connection is between arduino and 16x2 LCD screen.
Same as Arduino.cc tutorials
"LCD RS pin to digital pin 12
LCD Enable pin to digital pin 11
LCD D4 pin to digital pin 5
LCD D5 pin to digital pin 4
LCD D6 pin to digital pin 3
LCD D7 pin to digital pin 2
Additionally, wire a 10k pot to +5V and GND, with it's wiper (output) to LCD screens VO pin (pin3). A 220 ohm resistor is used to power the backlight of the display, usually on pin 15 and 16 of the LCD connector"
Step 2: Includes
We should include and declare LCD to use it. With adding those lines to beginning of sketch
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Then declare Second , Minute and Hour
int sec=0;
int min=0;
int hr=0;
You can change those if you want start Stopwatch from another hr/min/sec
Ex : int sec=50 will start stopwatch from 50. second
Step 3: Setup
We will start the 16x2 in void setup()
void setup() {
lcd.begin(16,2);
Hint : We can add countdown before stopwatch starts with adding these lines to void setup
lcd.print("CHRONOMETER");
delay(1000);
lcd.setCursor(0,0);
lcd.print("STARTS IN 5");
delay(1000);
lcd.clear();
lcd.print("STARTS IN 4");
delay(1000);
lcd.clear();
lcd.print("STARTS IN 3");
delay(1000);
lcd.clear();
lcd.print("STARTS IN 2");
delay(1000);
lcd.clear();
lcd.print("STARTS IN 1");
delay(1000);
lcd.clear();
lcd.setCursor(0,0);
Step 4: Loop !
This part counts second
main key is
sec=sec+1;
this line adds 1 to second on every loop
we will add
sec=sec+1;
delay(1000);
to mainloop for counting second
Step 5: Oh Wait ! Forgot Minutes and Hours
We will add those lines for convert second to hours and minutes
if(sec == 60){ //This "if" will add 1Minute to min and reset second
sec=00;
min=min+1;
}else;
if(min == 60){ //This "if" will add 1Hour to hr and reset minute
min=0;
hr=hr+1; }
else;
Step 6: Print to LCD !
We will add those lines to beginning of loop for print values to lcd
lcd.setCursor(2,2);
lcd.setCursor(4,0);
lcd.print(hr);
lcd.setCursor(6,0);
lcd.print(":");
lcd.print(min);
lcd.setCursor(9,0);
lcd.print(":");
lcd.print(sec);
and add
lcd.clear();
to end of loop for clear lcd on every loop
Step 7: Full Code
/*Arduino Chronometer V1.0*/
#include LiquidCrystal lcd(12, 11, 5, 4, 3, 2); int sec=00; int min=00; int hr=00;
void setup() { lcd.begin(16,2); lcd.setCursor(2,1); lcd.print("CHRONOMETER"); delay(1000); lcd.setCursor(0,0); lcd.print("STARTS IN 5"); delay(1000); lcd.clear(); lcd.print("STARTS IN 4"); delay(1000); lcd.clear(); lcd.print("STARTS IN 3"); delay(1000); lcd.clear(); lcd.print("STARTS IN 2"); delay(1000); lcd.clear(); lcd.print("STARTS IN 1"); delay(1000); lcd.clear(); lcd.setCursor(0,0); }
void loop() {
lcd.setCursor(2,2); lcd.print("CHRONOMETER"); lcd.setCursor(4,0); lcd.print(hr); lcd.setCursor(6,0); lcd.print(":"); lcd.print(min); lcd.setCursor(9,0); lcd.print(":"); lcd.print(sec); sec=sec+1; delay(1000);
if(sec == 60){ sec=00; min=min+1; }else; if(min == 60){ min=0; hr=hr+1; }else;
lcd.clear(); }
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    Ok but how to stop the timer....
