Introduction: Simple Automatic Bathroom Fan
Welcome Back!
I have in this project made a moist sensor that activates the bathroom fan if the moisture get's to high. (>50%)
The problem was that the fan was always on if the bathroom lights were turned on. I could have installed a new fan with moist sensor instead but i didn't want to pay for one and I had all the parts laying around.
Here we go!
Step 1: Parts You Will Need
All the part's needed for this projects depends on your fan.
Some Fans are 12V DC and others are 220/110V AC.
Mine was 220V AC.
Parts:
Wireing box/project box
Arduino Pro Mini: https://www.ebay.com/itm/191679508570
Relay: https://www.ebay.com/itm/1PCS-5V-One-1-Channel-Rel...
DHT11: https://www.ebay.com/itm/New-DHT11-Temperature-and...
AC-DC Converter: https://www.ebay.com/itm/AC-110V-220V-TO-DC-5V-12V...
FT232: https://www.ebay.com/itm/FT232RL-FT232-USB-to-Seri...
Step 2: Soldering
Now it's just a bit of soldering.
Following the schematic should be fairly easy.
Step 3: Programming
Using the code in this step will give you a line that is set to 50% humidity. if you live in an area where this normal you can just pump up that number :-)
Our normal humidity is approx. 20%
And this is where you will need the FT232 to upload your code to the Arduino.
Step 4: Done!
Now that your have finished soldering and uploading the code, it should work!
Try testing it by breathing on to the moist sensor to see if the relay switches.
Last thing to do is to wrap it up in the box. but make sure the moist sensor is sticking out! and place it as high as possible. This is where the moisture will be when you are taking a shower or pouring boiling water on to your floor... don't ask me why you would to something like this.
If you liked the project feel free to hit subscribe to see more practical and not practical projects!
and then there is the vote button.. I wont force you.. but if you don't.. who knows what might happen?
