Simple Automatic Chicken Coop Door
218,689
406
113
Published
Introduction: Simple Automatic Chicken Coop Door
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with.
In this Instructable I'll be showing how to make an easy automatic chicken coop door opener.
For anyone who keeps chickens, the ever present threat of predator animals like foxes is always a worry. We recently had all of our chickens (4 of them) killed by a fox and as you could imagine it wasn't a pretty sight. Usually when something like this happens its due to human error, like leaving the coop open. I wanted to ensure that this didn't happen again and so started investigating automatic coop doors. There are quite a few on the web, many expensive or just plain complicated. After much searching I finally stumbled across one which seemed like pure genius.
The door is lifted and closed by an electric car antenna which is activated by a timer. Simplicity itself! Electric antenna's are easily available from any car wreckers for next to nothing, and it's a great way to re-use something that just going to be land-fill anyhow!
There are a few versions on the net on how to make this door opener. I noticed though that they all used a couple of computer charges to power the antenna which made it complicated. My version uses a timer and battery and keeps everything simple.
The reason why I have included the word "simple" in the title is this really is an easy build. If you do a quick search on the net you'll see a bunch of builds which either cost a heap or seem really complicated. This project can be done for as little as $20 if you use mains power.
The following Instructable will take you through how to wire-up the timer and antenna and also how to mount to the door.
Your chickens ill thank you!
I've also included a short video of the door in action.(if you are using a mobile, try this link)
Enjoy
Step 1: Things to Gather
Parts:
1. Electric car antenna - you can get these from your local wreckers if you have one. Alternatively you can get them on eBay
2. Timer - I used this one from eBay
3. Power supply. You can use either a 12v battery or a 12v power source. I went with a 12v battery so if there were any power outages then it would still keep on going. The battery I scavenged was also from the wreckers and only cost me $10
4. Various wires
5. Terminal Strip - eBay
6. Screws.
- Small ones (they need to fit into the C channel
- Larger ones to screw everything together
7. Aluminium C channel - Hardware store
8. Voltage Meter - eBay (optional)
9. Small switch (optional)
10. Solar Panel - eBay
11. Solar regulator - eBay
Tools:
1. Bench Saw
2. Hot glue
3. Soldering iron
4. Super Glue
5. Drill
Step 2: Testing the Antenna and Timer
Its a good idea to first test the antenna and timer to ensure that everything works
Steps:
1.  Use the schematic below to help you with the wiring.
2.  You can use either a 12v battery or power source to power your antenna and timer.  You need to make sure though that the antenna has constant power.  When the power is active the antenna retracts and when the green wire (usually green but it could be another colour) is attached to the red wire, the antenna will extend.
3.  if you have everything hooked-up correctly, then when the timer is on the antenna will retract, and when the timer is off it will extend.
Step 3: Planning the Door
So now you have tested the antenna out and if everything is working, you’ll now have to think how you are going to mount it inside your chicken coop.
There are many types of coops and most people will probably have a unique arrangement.  Your door should be located in a spot where there is a lot of room and at a high spot in the coop.  The reason for this is so the antenna has enough room to move up and down.  Also, the battery etc can take up a lot of room, so you need to be wary of where this will go in the end.
Once you have decided where to put the door, you need to then design exactly how the door will work.  Depending on how your coop is made, this could be easy or really challenging.  As you can see from the photos below of my coop – I had a large area where the door to my coop is and decided to use this section to add the chicken door.
Step 4: Making the Door - C Channel
The C channel is what will keep the door in the right position.  For those who don’t know, C Channel is usually a long piece of aluminium shaped like a “C”
Steps:
1. Cut 2 equal lengths of wood.  Mine were 1500mm by 80mm.  I used fence palings for all of the wood that I needed.
2. Next grab your C channel and drill some holes aprox 300 mm long the inside of the channel.  Use a larger bit and drill out the top of the hole so the screws you use sit flush in the channel.  Do this twice.
3. Screw the C channel into the wood as shown.  Make sure that the wood is as straight as possible when attaching the C channel.  You will probably have some bend in the channel once it is screwed into the wood, but once they are attached to the coop they should straighten out.
4. Next attach the wood and C channel to the coop.  Make sure that when attaching the C channel that the distance between both of them is the same from top to bottom.  Remember, the door needs to slide up and down along these channels so they need to be straight or it will jam.
Step 5: Mounting the Antenna
Once you have the C channels attached to the coop, you will then need to work out how to mount the Antenna so it is directly above.
Steps:
1. Out of some thicker wood, create a bracket like the one below. Having 2 sides on the wooden bracket will help give it more strength.
2. Attach the wooden bracket to another piece of wood. This will be the backing. I just used a piece of fence paling.
3. Decide where you want the antenna to be mounted on the bracket. Once you have worked out the best spot you need to screw it into the top of the bracket. The best way to do this is as follows:
a. Use a piece of masking tape and put it across the 2 holes in the bottom of the antenna.
b. Mark with a pen exactly where the middle is.
c. Remove tape and stick it to the top of the bracket.
d. Drill where marked
You should now have 2 holes in the top of the bracket perfectly lined up with the antenna.
4. Bolt the antenna into place
5. I also added a cable tie by drilling a couple of holes into the backing and using a cable tie for extra support around the antenna.
Step 6: Attaching the Wires
So now you have the antenna attached to the coop – the next step is to wire everything up.
Steps.
1. Cut a piece of wood the same length as the one you mounted the antenna to.
2. Decide where you want the timer to go.  Remember, this bit of wood will need toget attached to the wooden bracket that the antenna is attached to so make sure you choose the best place to locate the time.  Glue on with hot glue.
3. Drill 2 holes in the wood at the top of the timer and 3 at the bottom.  These will be for the wires to go through
4. On the back you need to attach a wire terminal.  This should go pretty much behind the timer.  Screw into place.
5. Add the wires to power the timer.  These are the ones that go into the top of the timer and attached them to the terminal.
**There is a schematic below which should hopefully help you as to how this is done.  It’s pretty easy really; just make sure that the positive and negative wires are in the right positions!**
6. Attach the board to the wooden antenna bracket
7. Lastly, attach all of the wires from the antenna to the timer
Step 7: Attaching the Antenna to the Coop
Once you have The antenna mounted in thew wooden bracket, its time to attach it to the coop.
Care must be given as to where you mount the antenna as you will need it high enough so the door fully opens, and also it will have to be straight.  The good thing about most of these antennas is they do have some play in them so if you happen to have it a little crookedly, it shouldn’t matter too much.
Steps:
1. Use some bolts and nuts to mount the antenna to the boards that the C channel is running along.  When mounting the antenna try and have it extended fully – this will help you mount it straight.
2. When mounting, if you find that the antenna is too long you can do a couple of things.
a. Superglue the first length of antenna to the second length.  This way the antenna won’t fully extend.
b. Cut the antenna.  You will need to be careful when doing this as I’m pretty sure that the antenna will have issues extending again if it is fully retracted.  You can cut it, just don’t retract until you have added the nut to the end (more on that later)
Step 8: Making a Door
Steps:
1. First measure the gap between the C channels and the height from the ground to where the door needs to end.
2. Cut out a piece of plywood to fit the gap.  You might have to trim 3-5 mm off one side of the plywood (I did)
3. Slip the door between the C channels making sure that the door moves smoothly up and down the C channel
Step 9: Attaching the Door to the Antenna
Now you are ready to attach the door to the antenna
Steps:
1. First – you need to find a way to attach the antenna to the door. He is how I did it and I have also suggested a couple of other ways.
The Way I did it Initially
1. First find a long, thin bolt. The door will be screwed onto this.
2. Next find fastener which has an insert screw in the side like the picture below. Use a small blow torch and solder the head of the bolt to the fastener.
3. Cut the end of the antenna off and thread on the fastener / Bolt. Tighten up the insert nut.
4. Now you should have a horizontal bolt sticking out from the vertical antenna. Make sure that the fastener is done-up tightly.
A Better Way
Recently I had to replace the bolt as it failed at the solder point. So, instead of soldering, I decided to just drill a hole through the neck of the bolt and threaded the antenna through it. To keep the bolt in place, use some drill stop collars like in the images below. These are great and will keep the bolt in place.
Step 10: Adding a Solar Panel and Voltage Meter
If you go down the battery route you'll need to ensure that the battery is kept charged. You can just add a drip charge if you like but this means it will need to be plugged in the a wall socket and kind of defeats the purpose. The easiest way to keep the battery charged is to use a solar panel to keep the battery charged.
Steps:
1. Attach the solar regulator to the wall of the chicken coop. Make sure its close to the antenna and battery
2. Add wires to your solar panel and if necessary make a frame for the solar panel so it sits on an angle. You'll only need to do this if the sun doesn't directly hit the panel.
3. Add the wires from the panel to the regulator.
4. Next add the wires from the battery to the regulator.
5. Lastly I decided to attach a voltage meter to the battery so I could easily check how much power the battery has. All you need to do is to add a switch to the meter and attach the wires to the regulator where the battery connects to.
Step 11: Testing and Running
Hopefully you now have a function, automatic chicken coop door!
So what’s next? You should now test it and make sure that everything is working as it should. Set the time so the antenna retracts (door opens) for the morning and have it shut at night. Keep an eye on it for the first few times and check the voltage level of the battery regularly.
Timer -
When using the timer it should be set on “auto”. This will mean it is using the times set to open and close.
If you do need to lower the door for any reason, then you can change the timer to “on” and the door will lower.
Raising and lowering can also be done by hand – all you have to do is carefully push the door up and down. Don’t go too fast or you will could possibly wreck the gears in the antenna.
Power supply -
You could easily run the antenna off the mains by using a 12v DC plug. It would all depend on how long your battery stays charged for. You don't really want to have to charge it every couple of weeks (kind of defeats the purpose of having an automated door!
I will be adding a solar panel soon to the battery so it is being charged each day.
Things I learnt
Initially I thought that all of the C channel would have to be perfectly straight and that the antenna would need to aligned up just right. Turns out that the antenna has quite a bit of flex and there is some room for error - not much room mind you, but enough to enable you to install the antenna by sight.
The important thing about the C channel is to have the same distance between them from top to bottom. Also to make sure that there are no bends or curves when mounting to the coop. If you can do this then you won't have any issues. The don't even have to be vertically straight - as long as everything else is mounted at about the same angle.
Also, when you attach the door to the antenna there is some movement that the antenna can absorb. This is a good thing, especially if the antenna is not mounted perfectly straight.
Thanks for looking and I hope this has inspired you to make your own automated chicken coop door.
Green Electronics Challenge
Runner Up in the
Gardening & Homesteading Contest
Fourth Prize in the
8 People Made This Project!
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
2 Questions
The link to the timer is broken. Can anyone provide a link to an equivalent timer. Also some specific instructions on how to program the timer would be helpful since instructions that come with the timer are written by someone who is not a native speaker.
I'm finding your tutorial really helpful. I intend to make one significant modification. I wish to use the same timer you are using to control two power antennas (operating two pop hole gates). I made sure the 12V power supply I'm using has enough amps to handle the double load. In your estimation, can you see any problem with how the antenna circuitry recieves its signal to open and close by having both antenna motors wired in parallel?
113 Comments
it worked fine for one month and now the motor is not working ( just buzzing) ...not sure what is going on? I will maybe get another motor and try a upside down pulley arrangement so the motor travels full motion.
oh man that's no good. Sound's like the motor burned out. Good luck with the re-build
could you just use this photocell switch in place of the timer ?
https://www.amazon.com/gp/product/B019BR5Y3U/ref=ox_sc_act_title_1?smid=A1K0O9XEM4PWVI&psc=1
You should be able to use one of these. You have to be careful though as you can't control when the switch decides what "dark" is and might close the door before the chickens are in the coop.
What solar panel did you buy on eBay? Also, what turned out to be the best solution to the power drain problem? Thanks!
lonesoulsurfer thank you, this is a very useful and interesting project and I would like to apply to my coop, but I'm not skilled in electricity...
could you draw a scheme of the electric connections including the solar panel?
thank you!
Alessandro
Tommy1983
How did you control how far the mast will extend and retract. Your video seems to show the antenna not fully retract or extending.
That's the beauty of it, you don't have to worry about controlling it as the antenna will stop once the door is down. They are built this way so the gears don't grind if something stops the antenna from going up. same thing when retracting.
I've only just seen this! what a great design. well done.
Great post! I used it to configure my coop door opener, but am also running into the battery drain issue, so I need to add another timer. In your second wiring diagram, I do not see a negative lead attached to the second timer. Is that connection not needed? Thanks for your help!
Hey there,
That's correct. You are just using the timer as an on/off switch.
I'm not a 100% sure that this will actually work without testing it first though. I don't see any issues with it so it should. All you want to do is to cut the power to the antenna 5 minutes after it has gone down, shutting the coop door for the night. It then needs to return power 5 minutes before the other timer kicks in and raises the door. The only thing that may go wrong is cutting the power might make the antenna retract. Don't think t will though.
Hi All! I am not at all mechanically inclined and I don't have anyone around who can help me with this, but I need to make one of these openers because I am having to keep my chickadoodles at a different location, so it would be great to not have to rush out at the crack of dawn to let them out everyday.
There is a lot of discussion about a 2nd timer and ways to keep the antenna from draining the battery. Can someone give me the bottom line on all of this? The more I read, the more overwhelmed I am feeling. I can hook this up to an electrical source, but ultimately I'd like to do a solar panel. If you can help me with some step by steps on anything that was added, I would be very grateful.
Thanks!
Tamie
Hey Tamie,
Don't really worry about the info in the discussions. These are just some ideas that people have had to help improve the build. Honestly though, I have been using my original set-up for over 2 years and haven't had the need to change anything. Just follow the original instructable that i wrote and you'll have a great working chicken coop door. The only thing that I have to change every 6 months or so is the battery as they don't really like being charge and dis-charged every day.. Other then that, you won't have to ever worry about not shutting the coop door.
Great! Thank you. I'll start gathering the pieces. Wish me luck!
No problem. if you get stuck, let me know and i'll be happy to help.
Are you using a DC or AC Timer?
When you click on the ebay link it shows both. Thanks for the help.
love it. I'm gonna make one but would like to use a power supply. What do I need for the antenna power? 12volt, how many amps?
