Simple Beaded Bracelet Patterns - How to Make a Crystal Beaded Bracelet With a Toggle Clasp
7,504
53
Posted in CraftJewelry
Introduction: Simple Beaded Bracelet Patterns - How to Make a Crystal Beaded Bracelet With a Toggle Clasp
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Look for simple beaded bracelet patterns? So lucky! Here I want to show you how to make a beaded bracelet with a clasp. Don’t leave; a fab crystal beaded bracelet is waiting for you!
Step 1: Materials Needed in Simple Crystal Beaded Bracelet Patterns:
6MM Abacus Glass Beads
Drop Glass Beads
Tiger Wire
Toggle Clasp
Crimp Beads
Step 2: Start to Make the Simple Beaded Bracelet Patterns
1st, cut off about 80cm tiger wire, slide a toggle clasp onto the middle of the wire
2nd, slide a crimp bead onto both wires and pinch it with flat nose pliers.
Step 3: Make the Basic Simple Patterns for the Crystal Beaded Bracelet
1st, slide a drop bead onto one wire, slide 4 abacus beads onto the other wire, cross both wires through another abacus beads and tighten wires;
Step 4:
2nd, add a drop bead to one wire, and add 4 abacus beads to the other wire as pictures show, cross both wires through another abacus and tighten wires;
Step 5:
3rd, repeat the basic pattern to make the rest crystal beaded bracelet until get your desired.
Step 6: Finish Simple Beaded Bracelet Patterns With a Toggle Clasp
1st, slide a crimp bead onto both wires, add a toggle clasp, and then pass the wires back to the crimp bead;
2nd, pinch the crimp bead to fix the end, and then cut off the extra wires.
Step 7: Here Is the Final Look of Simple Beaded Bracelet Patterns:
Good job! Now, the simple beaded bracelet patterns are done! Do you like this crystal beaded bracelet? Base on this tutorial on how to make a beaded bracelet with a clasp, you can design such simple and affordable crystal beaded bracelet for yourself. You deserve to have!
  • Trash to Treasure
    Trash to Treasure
  • Spotless Contest
    Spotless Contest
  • Microcontroller Contest
3 Comments
Looks so easy to make, yet it's so pretty. I'm going to make these in many different colors. Thanks so much, DasiyD.
Thanks so much! Nice day!
