I recently bought a Motobecane Super Mirage to replace a Grand Touring that was stolen from me and found that, unlike my previous bike, it has no space available to hold my Kryptonite U-Lock and cable. After a little googling with no satisfactory DIYs found, I decided to build my own lock holder.
Why not use the one Kryptonite sells you ask? Because they are absolute garbage, thats why. I had one and it broke after the first few potholes, not to mention the shear force required to remove the lock from the clamp!
The best part about this holder, unlike some other ways, is that its compatible with locks that have either side mounted keyholes or top mounted.
This instructable took me about 15 min to complete, is super simple and cost about $5 for the clamps, which might be cheaper depending on where you go.
(I already had the other tools around the apt.)
Ingredients:
Electrical tape
Flat head screwdriver
Scissors
Utility Knife
(2) 7/32"-5/8" Hose Clamps*
(2) 13/16"-1 1/2" Hose Clamps*
*The size of the clamps will vary depending on the make and size of your lock and on the width of the cross tube on your bike. Although the bigger clamps have some size to them so they should fit most.
Remove these ads by
Signing UpStep 1Wrap The Tape
Be extra careful to make sure the clamps will fall in the middle of the tape when installed. If you have brake lines or shifter lines running the length of this tube, make sure you tape under them or the clamps and/or tape will screw with the shifting and/or braking. The same applies when installing the clamps.
Did it with my masterlock aswell (the plastic holder it was shipped with is crap, really), seems to work fine!
