Simple Bluetooth Controlled Car
6,581
115
17
Published
Introduction: Simple Bluetooth Controlled Car
It is a simple Bluetooth controlled car.
It is easy to make using arduino and bluetooth module hc-05.
Hope you like to make it.
Step 1: Components Needed
1. Arduino Atmega8 or any board
2. Batteries
3. Battery clips
4. Breadboard
5. Motor Driver
6. Bluetooth HC-05
7. 2DC Motors & Chassis
8. Wheels
9. Connectors
10. Buzzer
11. LED's
12. Cable
Step 2: Circuit Diagram
Connect The Components As given in circuit diagram above.
Its Easy to Build.
Step 3: Uploading Sketch to Board
Step 4: Android Application
Install The Android application.First Pair your bluetooth module
Enter Passcode for bluetooth hc-05 is '1234'..
You can also make your own App using MIT Appinventor
Connect And Enjoy!!!
Step 5: Video
http://m.youtube.com/watch?v=fQx0DYtHwps
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    17 Comments
    but how to connect motor driver l293d chip with arduino
    please help im making it
    see the image make +5v & +12v common and connect 9v battery, make ground common of Arduino and l293d ic.
    then why you used two 9v batterys?
    one for arduino and other for driving two dc motors from l293d
    yeah i almost forgot about it
    well thank you my friend i think i will finish it soon
    See the circuit diagram, ic used is l293d.
    How can i connect l293d motor driver shield with arduino.Codes will work in arduino atmega 328?
    yes code will work on atmega 328
    connect D13,D12,D11,D10 pin to inpin1, inpin2, inpin3, inpin4 respectively.
    And what about inA and InB pins
    I am trying to make a Bluetooth control car
    Plz have u the code
    Motor driver has two inputs for one motor each. so connect pin 13,12 to moter 1 input and 11,10 to motor 2 input.
    Here is I1 I2 I3 I4 PINS ARE THERE AT
    SO I CONNECTED IT AS 2 TO 5 DIGITAL PINS OF ARDUINO RESPECTIVELY
    THIS IS NEW MODEL OF L298N
    AT THE BACK OF THESE PINS THERE IS 4 PINS MORE HOW TO CONNECT IT WITH ARDYINO
    IT IS WRITTEN THAT INA AND INB BOTHA HAs 2 PINS
