Simple Bots: Barreller
 by randofo
Featured
A Barreller Bot is a device that has seemingly eternal forward propulsion in a given direction. In other words, there is a motor that acts as an off-centered weight inside of a can. When the can rolls forward in the direction of the weight (the weight, being the motor), the motor turns upwards, hence, causing the can to roll forward again. Now, imagine this happening really quickly and for a sustained amount of time. It would give the can the appearance of rolling forward on its own and even cause it to do seemingly impossible things, like rolling up inclines. This bot is great fun! If you don't believe me, build one for yourself. It is quick and easy to do.
Step 1: Go get stuff
You will need:
(x1) continuous rotation servo modified for direct drive **
(x1) paint can (or similar)
(x2) 1" paintbrushes
(x1) 4 x AA battery holder
(x4) AA batteries
(x1) tilt switch (Mouser #107-2002-EV)
(x1) assorted zip ties
(x1) template (see below)
**Learn to remove a servo controller board at this page.
GASSYPOOTS in reply to GASSYPOOTSJan 8, 2012. 10:55 AM
i made a non robot one
axeman911 says: Dec 23, 2010. 7:35 PM
where can i get a servo motor?
randofo (author) in reply to axeman911Dec 23, 2010. 10:12 PM
axeman911 in reply to randofoDec 24, 2010. 7:49 PM
srry but sorta like hobby town?
randofo (author) in reply to axeman911Dec 25, 2010. 2:18 PM
Yes. Indeed.
ahaz says: Jul 10, 2011. 6:13 AM
wooohhh astig..
mangomango says: Dec 9, 2010. 6:19 PM
I made something like this but with rubberband power. on one end the rubber band glued or something and the other end is connected to a stick on the outside of the can. as the rubberband would unwind it would push the stick against the ground and push it forward. i might just make an 'ible for it now. Anyway, somewhat different ideas but excellent work
M4industries says: Aug 19, 2010. 10:06 AM
This is how they did the Chef Boyardee commercial a while back. Jamie Hyneman from Mythbusters was hired to do the effect.
HisDivineShadow says: Aug 9, 2010. 10:18 AM
I'm going to have to be the one to say aren't I? *sigh* DO A BARREL ROLL!
aouate3 in reply to HisDivineShadowAug 12, 2010. 5:09 PM
if u were to make two of them, half the width they are now, and have seperate control board, attach the two together so they can move freely, would it turn, if u get 2 board with the same frequency, it may be possible to use the same remote for forward, reverse, and steering if i had the time i would try it, but sadly i dont
aouate3 says: Aug 10, 2010. 6:04 PM
Did anyone try my idea? i tried it, but i found more success by using a belt instead of a gear, but u have to make the weight a little heavier
randofo (author) in reply to aouate3Aug 11, 2010. 11:01 AM
Do you have any pictures for people to see what you have done?
aouate3 in reply to randofoAug 12, 2010. 5:05 PM
I gave the one i made to a friend because i wasnt happy with the way it came out, it worked fine, but i did a diy with the barrel, and it was coming apart, im going to make a new one and ill take pictures, once i find some plastic xD, i got a heatgun so ill probably melt the plastic together instead of pvc glue
CaseBoy says: Aug 11, 2010. 7:19 PM
hay just found you and your amazing simple bots, and i have one suggestion. you could use those brushes for a-mazing bristle bot
ChrysN says: Jul 29, 2010. 4:49 PM
Cool, are you writing another book?
randofo (author) in reply to ChrysNJul 29, 2010. 5:02 PM
Nope. Just making bots.
hellvig in reply to randofoAug 11, 2010. 2:30 AM
Please, what are the paint brush handles for? Could they be replaced by something else, and in that case what would the requirements be then?
randofo (author) in reply to hellvigAug 11, 2010. 11:03 AM
They are there mainly to add a little extra weight across the can. Also, they help with zip tying the battery pack to the motor in an off-centered fashion (as it creates a larger surface area than the motor body). Replace them with anything you like.
aouate3 says: Aug 2, 2010. 10:49 PM
if you make sure the container is sealed, you could use it in water, it may float, and if it floats, it may be able to move around, and if you make it HUGE enough it may be able to go up things, QUICK SOMONE FIND A HUGE CONTAINER AND USE MY DIAGRAM, REPLACE THE ELECTRIC MOTOR WITH A WEED WHACKER ENGINE AND WEIGH IT DOWN WITH A CHAIR then follow these steps step one : get in step 2 : seal it up step 3, sit down step 4 : start engine step 5: pull throttle step 6: go down the street with it xD see peoples reactions step 7: try driveing it into a lake and see if it floats step 8: if you made it big enough, try going over things
aouate3 says: Aug 2, 2010. 10:44 PM
here is the diagram
aouate3 says: Aug 2, 2010. 10:43 PM
Here is part of the diagram, this takes care of the hard part, all that needs to be done now is to connect the postive and negative wires from the motor to the drive motor wires on the rc car circuit board, add a battery pack (use a mini rc car, may be easiest because bateries can get big, and the elctronics have to hang from the motor, along with a weight if needed... concept is that the motor is in a fixed postion but is moving the shaft, since the moter itself cant move in this configuration (if the motor has a weight on it) whatever is on the shaft will move, in this case being the round container... i havent tried it, idea took me seconds to think up, someone try it, i think it will work, as do a lot of my ideas
aouate3 says: Aug 2, 2010. 10:24 PM
if you want i can make a diagram
aouate3 says: Aug 2, 2010. 10:23 PM
take a cyliner like that, take a rod, put it through the center of the cylinder, attach a gear to the middle of the rod and a motor hanging on the rod freely and, add a remote control race car's controller board and hang it from the motor along with a battery and a weight, that school make it work a lot better, make go forward and backwards as long as the terrians incline isnt too high, i have been working on things like this for years, im 15 btw
J_K says: Aug 1, 2010. 8:56 AM
to steer it is impossible, isn´t it?
randofo (author) in reply to J_KAug 2, 2010. 8:11 AM
I was thinking of perhaps installing a moving weight along a track inside where the brush handles are. This, in theory, should make it slowly drift in one direction or the other.
xenor in reply to J_KAug 2, 2010. 6:09 AM
Pretty much, but I have seen a robot named Rotundus that was the same basic idea but in a sphere.
xenor says: Aug 2, 2010. 6:12 AM
We used to make a low-tech version of these as a kid, with an old tin, an elastic band and a few washers for weight. You'd basically wind it up by rolling in one direction, and let it go. Would roll up inclines quite well.
DoKToR2006 says: Jul 31, 2010. 7:59 AM
Cool robot. if there were no hole on the tube or bottle or what is it, it could run on water, too. Or use a sphere instead of the cylinder, and you have an atv. cheers.
TTSDA says: Jul 31, 2010. 5:09 AM
I will make it :) When its done I will leave a picture
napalm008 says: Jul 30, 2010. 10:47 PM
If i ad one of these things i would not have a clear housing and just let this thing roll down a highly populated area and watch people freak out.
kcls says: Jul 30, 2010. 6:13 AM
So all of your simple bots are using servos. Where are you getting your servos from? And what price? I'm going to try to make one of each bot and let them all go next to each other.
randofo (author) in reply to kclsJul 30, 2010. 10:13 AM
I'm getting them from Parallax. They are about $10 a piece.
zack247 in reply to randofoJul 30, 2010. 8:52 PM
could this work with a regular motor too?
randofo (author) in reply to zack247Jul 30, 2010. 10:16 PM
It would be harder to use a motor directly. The servo is nice because it is basically a geared motor which means that it both has more torque than a normal motor and spins slower.
hunter1125 says: Jul 30, 2010. 6:39 PM
This reminds me of the commercial with the ravioli can that travels to reach the one kids house. Its an old commercial that was on a few years back that I remember.
sageserver says: Jul 30, 2010. 3:49 PM
Cut the can in half and add another servo. Then put a rc set-up in and you can have a rc-atv(All Terrain Vehicle)-vehicle.
mrklaw says: Jul 30, 2010. 2:44 PM
I don't understand the purpose of the paint brush handles. Wouldn't it work the same without them? Are they there to support the wires inside so they don't drag?
Kiteman says: Jul 30, 2010. 2:23 AM
Make it in an opaque can, paint the words "follow me" on the outside, and then let it loose across a large open space.
Make sure you are videoing the result from a distance, of course...
randofo (author) in reply to KitemanJul 30, 2010. 10:14 AM
You would be surprised how many people asked me if it was a bomb when we were filming with it downtown. Speaking of which, we were kicked out of the private "public" space at 555 Howard St for filming robots. If anyone were to making a robot and want to film it, I recommend visiting 555 Howard St in San Francisco.
Kiteman in reply to randofoJul 30, 2010. 12:43 PM
Over the road from the Temple Night Club?
(Although, going by Google Street View, 555 is a car park under a bridge... )
randofo (author) in reply to KitemanJul 30, 2010. 1:44 PM
It's the giant skyscraper the car park is connected to.
Kiteman in reply to randofoJul 30, 2010. 2:06 PM
Ohhh...
Kiteman in reply to KitemanJul 30, 2010. 3:13 AM
Oh, no, stencil the words "follow me" in translucent paint on the clear can, then paint it black over the rest of the can.
Light inside the can with LEDs, and then set it off across an open space at night.
cory.smith says: Jul 30, 2010. 6:35 AM
Very Cool. I love the paint brush handles.
KellyTheAlien says: Jul 29, 2010. 8:51 PM
What is/where did you get the clear can? I think the cool part of the project would be being able to see the motor inside at work, so I don't want to work with an opaque paint can.
Kiteman in reply to KellyTheAlienJul 30, 2010. 2:21 AM
Try a sweet-shop - our local sweet-shop gives the empties away for free, and some of them are cylindrical.
randofo (author) in reply to KellyTheAlienJul 30, 2010. 12:38 AM
There is a craft store chain in California called Beverley's. They sell it to use for party favors (presumably).
M.C. Langer says: Jul 29, 2010. 8:26 PM
I love your simple bots, Randofo. They're great for people (like me) who doesn't know about electronics but loves the robots!!!!
MrAngryPants says: Jul 29, 2010. 5:31 PM
Can from the Chef Boyardee commercial anyone? (http://www.youtube.com/watch?v=An__erKclS0&feature=player_embedded If you don't know what I'm talking about.)
randofo (author) in reply to MrAngryPantsJul 29, 2010. 5:41 PM
Yeah... like that, but real.
mweston in reply to randofoJul 29, 2010. 7:25 PM
Actually, I think that was real, at least some scenes were! Jamie Hyneman (Mythbusters) was the mastermind behind it -
http://m5industries.com/m5i_2.html
The cylinder in the front of the image is the Chef Boyardee can without the label.
Munchys says: Jul 29, 2010. 5:56 PM
Be funny to do this in a can and let it roll around on the street
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
