What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
A Barreller Bot is a device that has seemingly eternal forward propulsion in a given direction. In other words, there is a motor that acts as an off-centered weight inside of a can. When the can rolls forward in the direction of the weight (the weight, being the motor), the motor turns upwards, hence, causing the can to roll forward again. Now, imagine this happening really quickly and for a sustained amount of time. It would give the can the appearance of rolling forward on its own and even cause it to do seemingly impossible things, like rolling up inclines. This bot is great fun! If you don't believe me, build one for yourself. It is quick and easy to do.
(x1) continuous rotation servo modified for direct drive **
(x1) paint can (or similar)
(x2) 1" paintbrushes
(x1) 4 x AA battery holder
(x4) AA batteries
(x1) tilt switch (Mouser #107-2002-EV)
(x1) assorted zip ties
(x1) template (see below)
**Learn to remove a servo controller board at this page.
I made something like this but with rubberband power. on one end the rubber band glued or something and the other end is connected to a stick on the outside of the can. as the rubberband would unwind it would push the stick against the ground and push it forward. i might just make an 'ible for it now. Anyway, somewhat different ideas but excellent work
if u were to make two of them, half the width they are now, and have seperate control board, attach the two together so they can move freely, would it turn, if u get 2 board with the same frequency, it may be possible to use the same remote for forward, reverse, and steering if i had the time i would try it, but sadly i dont
I gave the one i made to a friend because i wasnt happy with the way it came out, it worked fine, but i did a diy with the barrel, and it was coming apart, im going to make a new one and ill take pictures, once i find some plastic xD, i got a heatgun so ill probably melt the plastic together instead of pvc glue
They are there mainly to add a little extra weight across the can. Also, they help with zip tying the battery pack to the motor in an off-centered fashion (as it creates a larger surface area than the motor body). Replace them with anything you like.
if you make sure the container is sealed, you could use it in water, it may float, and if it floats, it may be able to move around, and if you make it HUGE enough it may be able to go up things, QUICK SOMONE FIND A HUGE CONTAINER AND USE MY DIAGRAM, REPLACE THE ELECTRIC MOTOR WITH A WEED WHACKER ENGINE AND WEIGH IT DOWN WITH A CHAIR then follow these steps step one : get in step 2 : seal it up step 3, sit down step 4 : start engine step 5: pull throttle step 6: go down the street with it xD see peoples reactions step 7: try driveing it into a lake and see if it floats step 8: if you made it big enough, try going over things
Here is part of the diagram, this takes care of the hard part, all that needs to be done now is to connect the postive and negative wires from the motor to the drive motor wires on the rc car circuit board, add a battery pack (use a mini rc car, may be easiest because bateries can get big, and the elctronics have to hang from the motor, along with a weight if needed... concept is that the motor is in a fixed postion but is moving the shaft, since the moter itself cant move in this configuration (if the motor has a weight on it) whatever is on the shaft will move, in this case being the round container... i havent tried it, idea took me seconds to think up, someone try it, i think it will work, as do a lot of my ideas
take a cyliner like that, take a rod, put it through the center of the cylinder, attach a gear to the middle of the rod and a motor hanging on the rod freely and, add a remote control race car's controller board and hang it from the motor along with a battery and a weight, that school make it work a lot better, make go forward and backwards as long as the terrians incline isnt too high, i have been working on things like this for years, im 15 btw
I was thinking of perhaps installing a moving weight along a track inside where the brush handles are. This, in theory, should make it slowly drift in one direction or the other.
We used to make a low-tech version of these as a kid, with an old tin, an elastic band and a few washers for weight. You'd basically wind it up by rolling in one direction, and let it go. Would roll up inclines quite well.
Cool robot. if there were no hole on the tube or bottle or what is it, it could run on water, too. Or use a sphere instead of the cylinder, and you have an atv. cheers.
So all of your simple bots are using servos. Where are you getting your servos from? And what price? I'm going to try to make one of each bot and let them all go next to each other.
It would be harder to use a motor directly. The servo is nice because it is basically a geared motor which means that it both has more torque than a normal motor and spins slower.
This reminds me of the commercial with the ravioli can that travels to reach the one kids house. Its an old commercial that was on a few years back that I remember.
I don't understand the purpose of the paint brush handles. Wouldn't it work the same without them? Are they there to support the wires inside so they don't drag?
You would be surprised how many people asked me if it was a bomb when we were filming with it downtown. Speaking of which, we were kicked out of the private "public" space at 555 Howard St for filming robots. If anyone were to making a robot and want to film it, I recommend visiting 555 Howard St in San Francisco.
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
Or online:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/102/Default.aspx
Make sure you are videoing the result from a distance, of course...
(Although, going by Google Street View, 555 is a car park under a bridge... )
