Simple Bots: Inchworm
If you can count on only one thing, it would be a ruler. Now, don't get me wrong. I am not talking about supreme despots for life, or anything of that sort. The rulers that I am referring to are the measuring kind. After all, how can you not count on something with so many sequential numbers? That is why when it came to deciding what the armature for Inchworm Bot should be, the only thing I could of was my good, dependable, friend, the ruler. After all, in the grand scheme of things, there is merely inches of similarity between the two.
If you like this bot, please check out all of my other Simple Bots.
Step 1Go get stuff
Go get stuff
You will need:
(x1) 18" aluminum ruler (or longer)
(x2) small tupperware
(x2) 2" - 3" fixed casters
(x1) Servo modified for direct drive***
(x1) Bic Classic pen
(x1) Comb
(x10) small nuts and bolts
(x4) small washers
(x1) 2" - 3" metal standoff
(x4) zip ties
(x1) DPDT lever switch
(x1) 4 x AA battery holder
(x4) AA batteries
(x1) red and black wire
(x1) electrical tape
**Learn how to modify a servo motor for direct drive at this page.
41 comments
1-40 of 41next »
Oct 2, 2010. 3:21 PMstrider_mt2k says:
I was so inspired by your work that I put an inchworm bot together out of industrial scrap at work.
The only thing that's new is the gear motor.
http://www.flickr.com/photos/strider_mt2k/sets/72157625069322244/
I look forward to building more simple bots like yours out of industrial scrap!
Thanks for getting the wheels turning in my head!
Oct 11, 2010. 7:16 PMboston09 says:
this was a fun project, thank you.
i might add some wheels soon
Oct 15, 2011. 8:18 AMsviswanathan says:
this is the most complicated model to make...
really tough
my switch isnt being flipped
could someone help me?
Aug 16, 2011. 2:51 PMjmacco says:
great projet, i like it and is my project for the science fair
May 6, 2011. 3:28 AMkhobis says:
it's really an awesome project.. i'm gonna build it as soon as i collect those stuff's
Apr 5, 2011. 11:16 PMzap8004 says:
could you use a 12' ruler
Apr 8, 2011. 12:31 AMzap8004 says:
do I need to change other mesurements
Dec 30, 2010. 8:44 AMbears0 says:
i want to use a servo driver for RC cars, it has two servos and i want to substitute a servo for a motor, i'm planning on making an electric boat and i cant use a servo to make it go, if someone could tell me how it would be greatly appreciated.
Dec 24, 2010. 8:26 PMaxeman911 says:
what is an arduino?!!!
Dec 25, 2010. 6:37 PMaxeman911 says:
thanx
Sep 12, 2010. 4:07 PMCarnavislol says:
can the Tupperware be about 3" tall?
Sep 10, 2010. 4:35 AMCarnavislol says:
wait should i get the continuous rotation servo motor or t he standard one...
Sep 8, 2010. 4:46 AMCarnavislol says:
That so awesome! I'm gonna build it soon with my friends! Very explanatory guide!
Aug 19, 2010. 10:31 PMhyw_scott says:
Nice, try to make one.
Aug 14, 2010. 3:28 AMKiteman says:
A few broom bristles, taped to the side of the boxes, angled towards the rear and projecting slightly below the boxes should encourage forward motion, especially on carpeted surfaces. (Another nice one, Randy!)
Aug 19, 2010. 6:38 PMmuskogee says:
also could you use a 9 volt instead of 4 AA's?
Aug 19, 2010. 6:35 PMmuskogee says:
Instead of using a comb... couldn't you use another ruler? Maybe a 8 inch plastic one would work.
Aug 16, 2010. 2:30 PMmatstermind says:
this reminds me of the most useless machine ever
Aug 13, 2010. 7:13 PMmacrumpton says:
Very cool. It occurred to me that if you had a pendulum on the joint that shifted a weight over the rear leg when you are pushing the legs apart and shifted the weight over the front leg when the legs pull together, that there would be a lot less slippage. another approach would be to use some wheels with a ratchet that allowed only turning in on direction.
Aug 13, 2010. 7:06 AMmasynmachien says:
Nice work, great Ible. As a kit I used to have a construction kit for an inch worm "robot" with at its "feet" wheels with a ratchet blocking any backwards movement. It moved quite fast. You could ad something similar with yours. If you want to avoid wheels (to keep a more annimal like type of propulsion) you could add something else that allows forward movement and block the forward movement. Inclined bristles should work, which would give birth to a completely new type of bristlebot.
Aug 12, 2010. 12:51 PMDr KAZ says:
I agree, the ruler RULES! It can be used to (indirectly) measure mass, capacitance, resistance, magnetic flux, velocity, etc. etc. etc. and if you are very creative it can be used to measure the iron content of spinach. Trusty old ruler. Thanks for a useful, clear, fun, cheap, instructable!
Aug 12, 2010. 11:50 AMinblack says:
Add some grip on the boxes and it sould run faster!
Aug 12, 2010. 9:48 AMWingDings says:
Great idea on the comb! That's a really innovative idea. Good work on the clear instructions and photos, too.
Could you also drill a larger hole in the ruler attached to the servo horn (the size of the other side of the servo horn that fits onto the servo spline), in the centre of the four holes that the servo horn bolts go through?
That way you could affix the servo horn, in the same orientation, but with the servo horn arms on the other side of the ruler and the spline side passing through the ruler. That would make the ruler attached to the servo horn a bit closer to the servo bearings, perhaps reducing the side-loading on the servo bearings?
Aug 11, 2010. 4:48 PMLindie says:
I was anticipating how you made an inch worm, till I saw it. Very nice! LOL!!!
Aug 10, 2010. 8:30 PMcory.smith says:
Thumbs up!
Aug 10, 2010. 5:51 PMfearme36 says:
"Inch"worm made out of a ruler. Bud dum tsss
Aug 10, 2010. 2:11 PMboston09 says:
in the pictures the servo is a standard sevro, but the list says a continuous rotation servo.. which one is needed?
Aug 10, 2010. 4:34 AMRe-design says:
Using the comb as a reverser was brilliant. An easy to adjust the movement.
Aug 9, 2010. 9:07 PMjam BD says:
nice simple and elegant complements on the photos by the way
Aug 9, 2010. 9:04 PMshinjiyuubix says:
hahahaha, simple and fun
Aug 9, 2010. 7:06 PMPatented says:
awesome I love the idea !
Aug 9, 2010. 2:19 PMkcls says:
I like that the switch turns back and forth reversing the motor. Ingenious!
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1975
Author:randofo(Randy Sarafan loves you!)
I am the author of the book '62 Projects to Make with a Dead Computer' and Community Manager here at Instructables. I'm always sharing tons of awesome projects. Subscribing to me = fun and excitement!
