3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Bots: Rolly
Simple Bots: Rolly
This Simple Bot was inspired by a work by artist James Rouvelle, called Colony, in which a bunch of odd-shaped ellipsoids self-propel around their environment. It is my understanding that his bots were made by placing a vibrating motor freely inside of a Styrofoam ball that was then coated to give it an irregular shape. This dynamic makes his orbs fluctuate between wobbling in place and jerkily moving around the room. While this is a cool interaction, I was more interested in making something that had a more regular motion and was able to roll steadily about. Towards this end, I have created Rolly Bot. To simply explain, Rolly is basically an over-sized tennis ball with an over-sized bristlebot placed inside. This allows Rolly to be rolled in whatever direction the bristlebot inside so chooses to drive.
Step 1Go get stuff
Go get stuff
You will need:
(x1) An over-sized tennis ball
(x1) AAA double battery holder
(x2) AAA batteries
(x1) Vibrating motor***
(x1) Small scrub brush
(x2) Zip ties
(x1) Cutting pliers
(x1) Razor blade
(x1) Coping saw or hacksaw (not pictured)
(x1) paper
***My vibrating motor came from a back massager from Walgreens. You can learn to make your own here.
83 comments
1-40 of 83next »
Aug 1, 2011. 1:43 PMThat One Eegit says:
would it be possible to use a smaller bristlebot in a normal sized tennis ball?
May 4, 2012. 8:38 PMwooohhhoooo9 says:
yes i tried it. you use a toothbrush to replace the scrub brush..and the batteries, i got them from a watch
Feb 25, 2012. 1:46 AMx-The Queen-x says:
How to run Is there a key to the on and off ?
Feb 25, 2012. 2:51 AMx-The Queen-x says:
Please Help me I have a project about it
Feb 25, 2012. 1:51 AMx-The Queen-x says:
Do you still work to be completed on battery power ?
Nov 13, 2011. 5:17 PMbuilding_boy says:
Hollow out a golfball and make it rc!
cheating!
Sep 7, 2010. 4:10 AMD_zeno says:
Where can I get/buy these kind of motors you used?
Sep 25, 2011. 2:01 PMDearden805 says:
You can buy them at radioshack for real cheap
May 22, 2011. 1:20 PMlalaman says:
Try any console controller like an XBOX controller or PS2 controller. It helped me :)
May 5, 2011. 5:22 AMTigrisLi says:
You can find a vibrating motor in a electric toothbrush
Dec 24, 2010. 10:33 PMhuksin says:
i think in a cellphone that's what i got
May 22, 2011. 6:32 PMLawlzdeep says:
A switch that can't get turned on/off accidentally would be a nice addition
Jul 30, 2010. 2:00 AMamklose says:
Does the bristlebot inside ever fall over?
May 22, 2011. 6:30 PMLawlzdeep says:
It seems that if the center of gravity is low enough it will always correct itself, that is if the bristlebot is big enough to never fall fully on its side without bumping into the inside of the ball.
Aug 25, 2010. 6:43 PMdmac208 says:
many times in guessing
May 22, 2011. 10:13 AMAnnaZed says:
That rolly robot is just so utterly charming. Even though I am an extreme neophyte I think that I could make that.
Question: do you think that it would endure the attentions of a feisty cat?
May 22, 2011. 10:11 AMmorad10s says:
in the controls of the play station these engines are.
Mar 10, 2011. 6:37 PMThe Dark Lord says:
9V is overkill. i tested it, and it was faster than fireworks on the 4th of July.
Mar 10, 2011. 7:27 AMThe Dark Lord says:
i will make one, and i will freak out my dogs. [and cats]
Feb 18, 2011. 9:44 AMcarlpogi_11 says:
im gonna make one and i will prank my friends hehe
Jan 8, 2011. 10:17 PMArc Trooper 5555 says:
I'm putting a 9V battery in mine! :)
Jan 13, 2011. 8:34 PMArc Trooper 5555 says:
I was joking and I have a much larger motor.
Jan 12, 2011. 8:22 AMukkr says:
Remove a ps2 controller and u will ind thos moters
Dec 2, 2010. 2:57 PMmara0192 says:
can anyone give me a website/part number of a motor like this, i'm new torobots and making things and i don't know where to look or what to search for one like this
Dec 29, 2010. 4:51 PMchrizw123 says:
Personal massager, eh?;) lol
Dec 24, 2010. 6:10 AMtypomaniac says:
this is pretty cool :-)
i have a general question: How do i find out, which is the right voltage for my motor? i do have some lying around but i do not know which voltage i should apply ...
thank you!
tm
Oct 3, 2010. 4:13 PMkevin.cwiok says:
I got everything hooked up and wired correctly and even put a push button on there to power it off and on ,new batteries also, however, when i remove the paper and turn the button on, the motor spins slowly or it just stalls. I'm sure the push button isn't putting up any resistance because it's merely there to complete the circuit. Do you have any suggestions for why it could be doing that?
Oct 3, 2010. 8:00 PMkevin.cwiok says:
I got it. It was the voltage after all. Another battery made it work perfectly. The motor said 3-6V so that extra battery really made a difference. Cool idea and it was perfect for my first project. thanks for your help!
Oct 3, 2010. 6:47 PMkevin.cwiok says:
Nothing is in the way of the weight and I'm using the motor from one of the massagers from CVS which looks practically identical to yours so I'm assuming 3V. I'm using 2 AA's. Should I try it with 4 of them?
Sep 5, 2010. 3:16 AMwareneutron says:
you have know simple robots.
you such a good work
Aug 10, 2010. 9:59 PMPirondizzle says:
What brand/type of back massager did you get to take the vibrating motor from? I can't find one that works with the AAA battery pack.
Aug 26, 2010. 7:30 AMthekid says:
I have old Xbox controllers that are broken and i just used those. any rumble controller should have come :-)
Jul 27, 2010. 9:12 PMWasagi says:
This is terrific! Could someone instead use a bristlebot and a tennis ball? Also, this is just solidifying my belief that randofo has an army of robots...
Aug 22, 2010. 11:33 AMking kolton9 says:
not as many as grant imahara off of mithbusters
1-40 of 83next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2357
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
