Introduction: Simple Braid
This is a very simple hair due that I love to wear because it's easy and fun. It works on medium and long hair, and you can do it on yourself, a doll, or someone else. I'm using an American Girl Doll=)
Step 1: Gather Your Materials
You will need...
•1 hairbrush and/or comb
•1 hair tie
•1 accessory (optional)
Step 2: Clean, Brushed, Combed, Parted
Before you begin, make sure the hair you're working on is cleaned, brushed, combed, and parted. This makes it easy for you and your hair.
Step 3: Section Off
Section your hair into three equal parts.
Step 4: Over
Take the leftmost section and bring it over to the middle.
Step 5: Over
Then take the rightmost section and bring it to the middle.
Step 6: Over
Then bring the leftmost section to the middle.
Step 7: Over
Then bring the rightmost section to the middle. As you can probably tell, the barmaid is simply a pattern that repeats itself over and over again. So continue this pattern until you have about one-two (1-2) inches of hair left.
Step 8:
Step 9:
Step 10:
Step 11: Tie It Off
To tie off your braid, wrap a hair tie around it as many times as needed.
Step 12: Add an Accessory
I made a small bow charm out of loom bands for an accessory, but many other things can be used, too!
Step 13: Different
I have three (3) different views of this braid. I hope you enjoy it and thank you so much for viewing!
Step 14: Check These Out, Too!
Check out my other hair tutorials:
•Messy Bun
•Pigtail Braids
•Twist Bun
•Flip Tail
Hair & Makeup Contest
