Simple But Powerful Rechargeable PowerBank
Published
Introduction: Simple But Powerful Rechargeable PowerBank
It's My First Instructable I wish that you all support me . PowerBank is very useful Gadget Today I am going to make simple and powerful PowerBank with some simple components
let's make it.
what we need for PowerBank
1. 4x lithium Ii-ion Batteries
2. 2x Tp4056 li-ion Charge Controller
3. 1x lm7805 Power Regulator
4. 2x25v 1000uf capacitor
5. 1x Diode 4007
Step 1: Batteries Stack
Solder two Batteries Positive terminal to positive and negative termination to terminal in parallel and same with other two Batteries that increase mAh of powerbank
Step 2: Combine Stack of Batteries
solder that pairs of batteries with negative to positive and left another negative and positive
Step 3: Connecting Charge Controller
Now connect Tp4056 with both stack positive and negative so on
Step 4: 7805 Regulator
Now make 7805 circuit and connect with battery stack with on off switch
Step 5: Testing
Check the output with Multimeter if not getting desired result check the all steps carefully
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    5 Discussions
    NOTE;
    you can add as many parallel packs to that BMS Protection Circuit PCB, it only shows you how to connect the BMS wiring in the middle of the series battery pack,,
    Please be very careful using this battery pack if you have not got a Series BMS Protection circuit and also individual Lipo Protection Circuits like this oneso you can protect each lipo battery - as an additional layer of protection
    NOTE2;
    Also if this is 8.4v output voltage, you may need a balance charger like the cheap and effective 2S or 3S chargers like this
    so if this is a 2P2S battery pack,, you will need a protection circuit, the TP4056 charging IC is really great as it stops charging once 4.25v is reached but it is HIGHLY advisable to also use a BMS Protection circuit like this:
    https://goo.gl/jWBDLn
    So that the charging is balanced for each series cell/parallel-pack
    Also 2 great websites for battery pack creation is;
    1. Battery University
    2. Lipo Wiring Webpage (Lipo Battery Packs)
    2 photo's illustrating the 2P2S battery pack;
    2P2S Battery Pack - with Balance wiring.png2P2S Battery Pack - without Balance wiring.png
    Congratulations with your First Instructable !!
    Welcome to the awesome world of sharing designs and idea's with the world :))
    Just a word of caution if you are soldering Lithium batteries in SERIES - you need a balance controller (BMS)
    If i have read your instructable correctly,, you have 2 batteries in parallel, and another 2 batteries in parallel.
    Then you have put the two parallel stacks in series, so your end battery pack is referred-to as a 2P2S battery pack;
    2P - 2 Parallel
    2S - 2 Series,
    This photo will show better what i think you have done;
    So is your end voltage of this battery pack 8.4v ? (assuming the batteries are at full charge approx 4.2v each stack of 2 parallel's,, then 2 parallel stacks in series to give 4.2v x 2 = 8.4v)
    Very thanks for your comment it's so valuable for me ?
