3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple CPVC blowgun and darts
This blowgun is very simple in theory and can be built in less than 30 minutes for under $5 using a 3 foot section of CPVC pipe with a female adapter as a mouth piece on one end and a piece of foam insulation to hold the darts.
There are three basic designs for blowguns. First is the standard one-piece gun which usually comes in lengths from 24 inches to 48 inches. There's the two-piece gun, which is usually 48 to 72 inches and finally you can buy a breakdown or backpacker style blowgun. The backpacker style blowgun usually breaks down into 3 or 4 pieces so you can store it in your backpack.
Modern blowguns tend to be made out of aircraft aluminum tubing.
You will need the following materials:
- 3 feet of 1/2" CPVC pipe (Home Depot/Lowes/hardware store)
- 1/2" CPVC female adapter (Home Depot/Lowes/hardware store)
- Ball point straight pins (Size/No: 20-1 1/4") (sewing store/Walmart)
- 2 inches of 1 1/2" pipe foam insulation (Home Depot/Lowes/hardware store)
- sheet of notebook paper
- superglue
- gluestick
Step 1CPVC Blowgun construction
1. Cut a 3' section of 1/2" CPVC and sand down any burs around both ends on both the outside and inside. This forms the blow gun tube.
2. Press on, but do not cement, a 1/2" female adapter onto one end of the 3' section of 1/2" CPVC. Try to find the female adapter's that have a rubber washer on the inside of the wide end. If you can't find one then purchase one. It should be 3/4" OD and 1/2" ID and 1/8" thick. The washer helps to prevent the dart from coming out. This forms the mouth piece.
3. Cut a 2" wide section of foam and wrap it around the CPVC tube 1' from the female adapter. This forms the dart holder.
39 comments
Feb 24, 2012. 6:11 PMfreeza36 says:
Hey i just wanted to know your input to the question that Higgs Boson, myself, and another one of our friends are all asking. What can be done to make the blowguns better at this point? Yours and ours are practically identical, except for the darts. Even with the best darts we can make, they still only ever shoot accurately at a max 35 feet. What do you think?
Dec 22, 2011. 10:29 AMwajahat_911 says:
Check this out ;)
http://www.instructables.com/id/Easy-Blowpipe-and-Dart-/?ALLSTEPS
Dec 23, 2011. 12:28 AMwajahat_911 says:
Thank you for the appreciation.. BY THE WAY.. I learned to make pin darts form your instructable!!.. THANK YOU :)
Jan 14, 2012. 5:12 PMfreeza36 says:
i use nail darts
Aug 28, 2011. 2:44 PMdom104 says:
it dont matter lossen up
May 10, 2009. 2:36 AMcrayzclown1 says:
use skewers for the darts, the added weight gives it more power
Aug 28, 2011. 2:28 PMdom104 says:
im just trying every dart i see
Nov 25, 2009. 11:29 PMcrayzclown1 says:
But less accuracy.
Dec 28, 2009. 10:41 AMscottmiller says:
 using nails seems to work well and it doesn't get blown around in the wind. Also I use index cards instead of paper and duct tape the outside it makes a really strong durable and waterproof dart that hit much harder than pins or skewers.
Aug 10, 2010. 1:06 PMManchesterUtd. says:
use wire hangers. they have more weight and i can get mine trough a fourth inch piece of plywood
Feb 17, 2011. 10:18 AMilpug says:
i use aluminum roofing nails, they are metal, but lightweight.
Aug 26, 2011. 7:15 AMvruiz3 says:
the epic debate
Dec 5, 2010. 5:57 PM3500 says:
i'm putting a 4x32 magnification scope to my blowgun. it should be the most accurate weapon i've had.
Dec 6, 2010. 5:53 PM3500 says:
thanks i will but i have to buy it first. i'm also painting it with red scorpion camo and the paint jobs arent going well so i have to keep trying. in a few weeks it should be done.
Dec 23, 2009. 1:00 AMmax_x says:
Very good job!  Keep up the good work! xD
Sep 5, 2009. 10:12 AMwakojako says:
glue a dressmakers pin to a ear cleany thing with the end cut off ad cone fire
Apr 23, 2009. 9:20 PMThundertydus says:
I cut some slits with my bandsaw into the adaptar and slipped in some wire mesh, to prevent the dart going in, surprisingly i only lost about half a foot of distance
Nov 18, 2008. 6:22 PMthebluemartyr says:
my cones are better, they require no trimming...
Apr 23, 2009. 9:18 PMThundertydus says:
Hahahahahaha -- Its Fred,Fred Burger!
I LOVE YOUR AVATAR
=D
Aug 23, 2008. 6:30 PMsmabber says:
very good, but the paper on the end of the darts often get soggy. I'd recommend making the darts with cut off coat hanger wire (then sharpen the points) and lots of strands of wool stuck on the ends to replace the paper cones. i love the blowgun design though!!!
Jan 7, 2009. 10:00 AMlasermaster3531 says:
i have a 5' long blowgun, and i use the paper from magazines for the darts because it don't get soggy. use jumbo paperclips for the point, you can hammer them into broadheads or file them really sharp. you can also choose how long the paperclip has to be, just fold the blunt end over in a small amount. the longer and skinnier the cone, the straighter they fly. the longer the barrel on the blowgun, the faster the dart goes.
Jul 9, 2007. 12:54 AMsgt.paper says:
just break down and by a real one people
Jan 7, 2009. 9:52 AMlasermaster3531 says:
this website doesn't give instructions for buying real blowguns. we make real blowguns!
Sep 13, 2008. 12:05 PMgeeklord says:
that defeats the purpose if this website, nitwit
Nov 13, 2008. 3:50 PMAnarchistAsian says:
yeah, seriously...
Nov 13, 2008. 3:51 PMAnarchistAsian says:
nice, i like how you used the adapter as a mouth piece...
Nov 12, 2008. 8:54 PMPuck13 says:
what does CPVC stand for (ive got some but want to know). thanks
May 22, 2008. 12:24 PMMattrox says:
Looks great 4 star rating
Jan 31, 2008. 7:55 AM371944a says:
yea cool I just shoot friends dog accidently
Oct 30, 2007. 11:27 AMnerfer192 says:
did this yesterday....shot chair...stuck into
Mar 1, 2007. 9:51 AMcasvandegoor says:
nice and neath worked out, I`ve got also a gun and cannon. come and watch!
Sep 26, 2006. 10:34 AMFrenchCrawler says:
The main intro text seems to have come from the first cached link. It was posted up 2001 (located at the bottom left of the page, right after "Conclusion")... "There are three basic designs for blowguns. First is the standard one-piece gun which usually comes in lengths from 24 inches to 48 inches. There's the two-piece gun, which is usually 48 to 72 inches and finally you can buy a breakdown or backpacker style blowgun. The backpacker style blowgun usually breaks down into 3 or 4 pieces so you can store it in your backpack. Modern blowguns tend to be made out of aircraft aluminum tubing." Granted some of the sentences have been changed, but the content is all the same. Are you trying to tell me that you placed your sentences in the order that the other site placed theirs by accident?
Sep 29, 2006. 11:34 PMFrenchCrawler says:
I was kind of expecting a yes or some kind of reply, too bad some people refuse to give credit where credit is due.... BTW, I'd like to visit your website after it's been moved.... maybe it'll give me some new ideas (kind of like this site did). Any chance we can have an address? Thanks for your time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
94
Author:jbb3141
Choose again.
