Introduction: Simple Cheap Ice Box Air Conditioner
In this instructable I will be showing you how to build a cheap air conditioner from a Styrofoam ice box. This is an extremely easy build and shouldn't take you more than an hour to complete.
I live away from home and cannot afford another air conditioner here so I thought of building a cheap air conditioner with things lying around the house. Summer nights are really uncomfortable and also pretty humid here(which is why I stayed away from the swamp cooler).
I hope you enjoy this instructable!
Step 1: Step 1: Materials and Tools
You will need the following:
Materials:
- Any sort of cooling fan, I had an extra exhaust fan lying around the house so decided to use it.
- PVC Pipes with elbow.
- Styrofoam Ice Box
Tools:
- Cutter Blade
- Hot glue gun
- Hacksaw
- Measuring instrument
Step 2: Step 2: Cutting Out the Holes for the Pipes and the Fan
The hole for the fan can be cut out using a cutter blade. However if you're using a thick box like mine, you will have problems cutting out the holes for a pipes with the blade, so I decided to the cut the holes using the pipe itself by slightly sharpening one of its edges. This does the job easily.
Step 3: Step 3: Attaching the Pipes and the Fan
I attached all the parts using hot glue, it does a fantastic job.
Step 4: Step 4: Add the Ice Packs
You can use any sort of ice, but if your box is big like mine, I would suggest freezing water in plastic packets and then putting them into the box. This way you won't have water collecting in the box.
Step 5: Step 5: You're Ready to Go
With the ice packets in the box and fan plugged in, sit back and enjoy your new Simple Cheap Styrofoam Air Conditioner.
Hope you enjoyed this instructable!
