For this project you will need:
1 - Male USB plug (got mine from a $1.50 Wii Intercooler)
1 - 22 ohm resistor (red-red-black) thats all I had, dunno if its perfect
1 - LED
Soldering/Desoldering Iron
Solder
Hot glue (optional)
Sorry about the bad pics
***NOTICE***
If you do anything wrong and screw up your computer, burn your finger etc etc...I'm not responsible!
It's a very easy project, but things could go wrong,
Remove these ads by
Signing UpStep 1Extract the USB plug
with your 22 Ohm resistor that led is getting the full 50mA (and more if it can get it).
your going to be burning your led out.... =\
you should be using a 200 Ohm resistor minimum (25mA) , you could be using a 500 Ohm resistor if you want (10mA).
if your using a ultra bright led (the clear ones) there still blindingly bright at 7mA. (700 Ohm resistor).
You are using U = R/I -> R = U*I, but you are using wrong U. U isn't voltage drop of the whole circuit, nor it's the supply voltage (witch is voltage drop of the whole circuit :P), but in this case it's voltage drop over the resistor. In this case power supply is 5 volts, voltage drop over led is something like 1.6-2.2V (it can be something else, but these are common voltage drops of red LEDs) that makes voltage drop over the resistor: 5V - 2.2V = 2.8V. Now this is the U we are going to use in R = U*I formula, when calculating the value of the resistor.
Lets say voltage drop over the led is 2.2V and we want 15mA : R = (5V-2.2V)/15mA = 2.8V/0.015A = about 187ohm.
