Simple Code for Arduino+keypad Door Lock Systems for Beginners
1,341
11
11
Posted
Introduction: Simple Code for Arduino+keypad Door Lock Systems for Beginners
Hello you all,
I've been working on a lock system for a while, I started looking for some codes to use in my project but unfortunately, I found a lot of complex ones, and most of them have some fails especially when they use pointers, you can try them and you'll find their problems.
And so I've decided to look through the Keypad library functions and I've found a way as a beginner to make a simple code, easy to use, easy to understand and easy to modify for you're own DIY projects.
Hope you like it.
You'll need:
-Arduino board:
-4x4 Keypad matrix (you can use the 4x3 but you have to do some modifications)
-LCD i2c screen
Step 1: Wiring and Code
The wiring is like in the picture.
And here's the code I used:
/* Arduino Unlocking code to use with you're own mechanism, here it's used to show a welcome or not <br> *  message on a lcd i2c screen
 *  The wiring is (keypad from 8to1) to arduino digital pins(9to2)
 *  lcd i2c on (5v,GND, SDA on A4 SCL on A)
 *  By SurtrTech
#include <keypad.h> //Libraries you can download them via Arduino IDE
#include <wire.h>
#include <lcd.h>
#include
<liquidcrystal_i2c.h></liquidcrystal_i2c.h></lcd.h></wire.h></keypad.h>
#define I2C_ADDR 0x27 // LCD i2c Adress and pins
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
int code = 1366;  //The code I used, you can change it
int tot,i1,i2,i3,i4;
char c1,c2,c3,c4;
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {9,8,7,6}; //Rows 0 to 3
byte colPins[numCols]= {5,4,3,2}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
void setup()
            lcd.begin (16,2);
            lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
            lcd.setBacklight(HIGH);
            lcd.home ();
            lcd.print("SurtrTech");
            lcd.setCursor(9, 1);
            lcd.print("Standby");
            delay(2000);
void loop()
      char keypressed = myKeypad.getKey();  //The getKey fucntion keeps the program runing, as long you didn't press "*" the whole thing bellow wouldn't be triggered
         if (keypressed == '*')             // and you can use the rest of you're code simply
               lcd.clear();
               lcd.setCursor(0, 0);
               lcd.print("Enter Code");                  //when the "*" key is pressed you can enter the passcode
                    keypressed = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed != NO_KEY)
                       c1 = keypressed;
                       lcd.setCursor(0, 1);
                       lcd.print("*");
                       c2 = keypressed;
                       lcd.setCursor(1, 1);
                       lcd.print("*");
                       c3 = keypressed;
                       lcd.setCursor(2, 1);
                       lcd.print("*");
                       c4 = keypressed;
                       lcd.setCursor(3, 1);
                       lcd.print("*");
                     i1=(c1-48)*1000;        //the keys pressed are stored into chars I convert them to int then i did some multiplication to get the code as an int of xxxx
                     i2=(c2-48)*100;
                     i3=(c3-48)*10;
                     i4=c4-48;
                     tot=i1+i2+i3+i4;
         if (tot == code) //if the code is correct you trigger whatever you want here it just print a message on the screen
          lcd.clear();
          lcd.print("Welcome");
          lcd.setCursor(7, 1);
          delay(3000);
          lcd.clear();
         else //if the code is wrong you get another thing
          lcd.clear();
          lcd.print("GTFO LOL");
          delay(3000);
          lcd.clear();
Step 2: Add to Your Own Project
As you see it's easy and simple.
Here I used it to show a message on the screen, you can add activating servos, relays, buzzers...
You can add it if you like to your projects,like generating passcode with an App using internet or bluetooth, or the ones when you set you're own passcode with the keypad...
Hope you like it.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    3 Questions
    Sorry to keep bothering you,
    When i upload the code to the arduino it says that the upload completes but nothing appears on the LCD.
    Might I also ask what libraries you used and where I could possibly download them?
    Thanks
    Hello, there's no problem asking, I'm ready to help, if the code uploads to your board that means there's no library problem.
    Here's the library for LCD i2c: https://drive.google.com/file/d/1Oc56q2GPs5SOA-Pdb...
    If your screen lights up but there's nothing try the i2c adress 0x3F instead of 0x27, or wire your lcd i2c and then run an i2c Scanner it will give you the adress.
    Sketch uses 5322 bytes (16%) of program storage space. Maximum is 32256 bytes.
    Global variables use 439 bytes (21%) of dynamic memory, leaving 1609 bytes for local variables. Maximum is 2048 bytes.
    This pops up
    That's normal, the sketch needs some storage and this one uses 16% of yours, this shows when you upload the code to the board.
    Is there a problem that you can't compile or upload the program?
    Hi,
    When i upload the code to my arduino the code is too large for it.
    Is there a way to fix this?
    Thanks
    Sorry I don't know what do you mean by "large"...
    3 Comments
    Works perfectly, thanks for all of the help!
    Well done, love it.
