loading
Picture of Simple Coin Pendant
This is a pretty easy instructable about how you can make a coin pendant out of just about any non-aluminum coin. Brass or bronze coins work best.
Make sure to check out my blog!
Now you can wear the coins you found or brought back from your travels!
You will need a little bit of soldering experience. The soldering here is pretty easy, so this project would make a pretty good introduction to jewelry making.
Step 1: What You'll Need
Picture of What You'll Need
Solder
Small Torch
Flux
Brass Pipe
Coin
Working surface (in this case, an upturned soapstone candle holder)
Small File
600 grit wetdry sandpaper
Step 2: Making The Bale
Picture of Making The Bale
Cut the brass pipe about 5mm from the end. You should end up with a little ring like the one in picture two. File the little ring until it's shiny (so the solder will stick to it)
Step 3: Prepping The Coin
Picture of Prepping The Coin
File the side of the coin where you want the bale to be soldered to. It needs to be shinny or the solder won't stick.
Step 4: Flux
Picture of Flux
Flux the area where the bale and coin touch. I use regular plumbing flux for soldering brass, steel, and bronze.
Step 5: Soldering Video
Picture of Soldering Video
Here's a quick video of me soldering it:
Step 6: Polishing
Picture of Polishing
Give the new pendant a quick polishing with some 600 grit wetdry, and you're done!
If you noticed, this isn't the same coin as the one in the intro...I wrecked this one before I took a picture of the final product...oh well :)
good idea really good finished product just wondering what sort of coin did you make the first one out of
thanks,
matthew
Awesome coin from my Awesome Pakisan
hey, i saw a coin necklace similar to this on your blog, i think it was travellers necklece. i was wondering how you get the background f the coins black. you didn't paint them did u. please tell me, they look pritty cool.
Depending on the metal you can soak them in bleach and sand the raised edges with a very fine sandpaper, or paint them with little bit of cooking oil and heat them gently with a torch or over a stove burner, if you watch closely the colors will progress from golden brown to black, then if you coat them with a very fine sheen of furniture wax you can get the color to hold.
nepheron (author)  shadow wave rider4 years ago
I just heat them with a torch until they start to glow a little, then I let them cool slowly in the air. The metal is black when they cool. To bring the design forward, i use fine wet dry sandpaper and polish off the black oxide on the highest parts of the design - making the coin look aged and worn.
sabu.dawdy4 years ago
thtz pak rupee :p
DIY Dave4 years ago
What kind of solder did you use?
nepheron (author)  DIY Dave4 years ago
I just used acid-core plumbing solder. You can get it everywhere. Make sure that it's LEAD FREE. Most solder these days is, but make sure you read the label first...
Thanks
paqrat4 years ago
I see where you said you use plumber's flux but you didn't say what sort of solder you used. I hope its lead free.
Hej! Really like how this one shows it is possible to not be overly handy and still make something nice for someone. And you definately found an easier way to work with these materials than many may think there is. My only less complimentary words concern the title of your instructable containing the word 'easy'. Sure enough it's an easy process, but i might (and as i've heard, has) mislead some people looking for even less complex tools and materials for this kind of jewelry.
Keep up the good work!
nepheron (author)  ColeKreviazuk4 years ago
Thanks!! I'm glad you like my project!
I think your point about the title is a very good one. 'Easy' is altogether too relative of a term... The process is 'simple', but not necessarily
'easy' for everyone.
thepete4 years ago
Silly question: could I use US currency for this project? I mean, assuming I didn't mind defacing government property? ;P (Like a penny is worth anything, anyway).
nepheron (author)  thepete4 years ago
You can use any coin you want.
However, it is illegal to deface a U.S. coin AND try to pass it off as regular money. It is perfectly legal to alter U.S. currency without any fraudulent intent.
Source of the following US Law Data:
331. Mutilation, diminution, and falsification of coins
Whoever fraudulently alters, defaces, mutilates, impairs, diminishes, falsifies, scales, or lightens any of the coins coined at the mints of the United States, or any foreign coins which are by law made current or are in actual use or circulation as money within the United States; or
Whoever fraudulently possesses, passes, utters, publishes, or sells, or attempts to pass, utter, publish, or sell, or brings into the United States, any such coin, knowing the same to be altered, defaced, mutilated, impaired, diminished, falsified, scaled, or lightened—
Shall be fined under this title or imprisoned not more than five years, or both.
end of source
Notice the word 'fraudulent'
Making necklaces is not fraudulent activity. Their is a lot of bad info online about this subject, and it is hotly debated. The actual law, though, speaks for itself. Making necklaces from U.S coins is perfectly legal as long as you do not try to spend the coins.
I hope that helps :)
-Nepheron
Definitely! Thanks, Nepheron!
555mst5554 years ago
did u heat it till it's glowing red?
nepheron (author)  555mst5554 years ago
Heat what? Do you mean the solder joint?
the coin.
Why would he need to heat the coin? You do realize that he's soldering, right?
you shut ur mouth you punkhead.lol! jkjk. sorry, i just had to do that.haha:) anyways, is flux expensive? coz i just need abit to try out this i'bles
Well, I suppose you are partially correct: the coin does need to be heated to about 700 degrees Fahrenheit in order for it to form an inter-metallic bond with the solder, but that's nowhere near it's point of malleability, and it's not going to get much hotter than that with a butane torch.
A lifetime supply of flux can be found at any hardware store for about $1.50. Don't get the water soluble stuff, that's for sissies. Get the stuff that has the big warnings all over it, it really works best!
lol. ok
ChrysN4 years ago
Nice, is that a rupee?
nepheron (author)  ChrysN4 years ago
Thanks!
I have no idea what the language it is, so I can't decipher it. I'm pretty sure it's not from India though, rupees usually have the lions-crouching-around-the-pillar-thing.
The one with the eagle is a mexican coin, it reads Estados unidos Mexicanos, wich translates to United States of Mexico, wich is the official Name of Mexico. and that eagle is the Symbol of Mexico. and the other one is Rupee
I think it's a peso.
probably, because "mexicanos" on the last pic obviously means mexico.
I think so too, but the one there is a different coin in the intro which I think might be a rupee because of the writing and the building on it.
It is a mexican coin...and is written in SPANISH....the translation is "United Mexican States"... Hi...from Puerto Rico..."The Caribbean Shining Star"
nepheron (author)  chicovargas4 years ago
There is two coins in this ible. One is a rupee, one is a peso.
There are two different coins the one in the last image is Mexican and the one in the intro appears to be a Pakistani rupee
Um...sorry an acquaintance of mine reads arabic it is a rupee
Its a Pakistani rupee. i am from pakistan so i know
nepheron (author)  skwisgaar4 years ago
Oh! I thought only india had rupees :D
You are correct, this is a rupee
Yes. it is a pakistani 1 rupee coin
looks like a Mexican coin
Kaiven4 years ago
Hmm... The solder... I would try using a little less solder perhaps. It is a nice looking coin!
nepheron (author)  Kaiven4 years ago
Thanks!
I use extra solder on purpose because I think It compliments the brass colors, and adds a nice transition color between the bronze coin and brass bale.
