Remove these ads by
Signing UpStep 1A Wordy Introduction to Composting and Tools You'll Need For This Project
For now, let's concentrate on building a simple, cheap, and useful compost container. To properly break down, composting matter needs the following: moisture, air, and time.
A full-enclosed container such as a plastic barrel or garbage bin will not work for composting as it does not allow enough air into the mix. So you end up with the stinky rotting stuff instead of the real compost. Compost has a somewhat pungent, but very earthy, healthy smell to it. Rotting stuff just makes you gag.
Moisture will come from water and from the items you ad to the compost pile. Kitchen scraps, grass clippings, weeds from your garden, etc. are all things you can ad to your compost pile. Everything from egg shells to uneaten vegetables to drainage from your cooking can be thrown on the pile.
Time, of course, is what it is. For a good sized compost pile to properly break down into useful soil mixture, it needs at least half a year, but a full year is generally better.
To build a good composting container, as I've shown above, all you'll need are:
- four fence posts--any kind, so long as they're at least four feet tall: wood, metal, whatever. They need to be sturdy and you should be able to somehow attach wire fence to them (screws, wire ties, staples, etc.).
- chicken/poultry wire or the equivalent. This needs to be of small mesh, so the openings can't be more than an inch square. Chicken/poultry wire is cheap and easy to come by, even used.
- organic matter like scrap wood, downed tree limbs, etc. of at least 13 diameter to use as a base for your heap.
Add Comment
