3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple DIY Hydroponics net pot/basket from recycled bottles
Quick, simple, easy and cost effective way to make your own net pot/basket for your hydroponics garden out of used/recycled plastic bottles and nylon mesh shower sponges. Unlike typical net pots/baskets, the opening is typically smaller, so the water evaporation is reduced. The design is also more flexible for different sized of holes to suspend these nylon net pots.
Step 1Material and tools
Material and tools
Materials and tools:
Materials:
1. A recycled plastic bottle, one with a plastic hoop around the neck like most soda bottles.
2. A nylon mesh. You can find it as packaging materials. Here I use a cheap nylon mesh showering sponge I got from Walgreens. 3 for $2.
Tools:
A scissor.
26 comments
Dec 20, 2011. 7:45 PMkovakyl says:
I made one of these in my window vertically useing plastic bottles. Turned out pretty good and was around 100 bucks all in all
You can check it out at youtube
http://www.youtube.com/watch?v=5AVQPIls-PI
Sep 10, 2011. 9:41 AMscottinnh says:
I -really- like this trick about the bottles. The funny thing is, recently I began just saving bottle necks and caps from soda water bottles.
I figured I could use them for something water-related, but wasn't sure just what for (I am a homebrewer and a gardener, so an application would eventually be found).
Apr 21, 2011. 7:29 AMnfarrow says:
what is your growing medium?
Jun 5, 2011. 7:21 PMgymnast says:
Fired clay balls.
Dec 1, 2008. 6:00 AMwiley coyote says:
Brilliant! I'm definitely going to use this idea somewhere. Who said this stuff needs to be expensive?
Jan 20, 2011. 7:55 AMfegundez1 says:
I have been having trouble with my hydro nutes because I needed a meter to find the E.C. Ahoy Ebay comes in I found a meter that does just what I want for under 20 bucks, of course you can spend as much as you want but I think the expensive ones are for commercial water systems and are sold to those of us who get suckered in by the high price means better BS. I have found though that using quality hydroponic nutrient and filtered water without chlorine etc added works well.
Dec 1, 2008. 1:35 PMwiley coyote says:
There is.... don't. Spend no money on such things until you need them, I would say. From what I've read and experienced, it will be less trouble and cheaper to just change your nutrient solution often, which will be necessary after all the testing and tweaking anyway. Your plants, reservoir size and method will actually dictate this rate among other things. I'm trying to re-invent the wheel, however, so you may not want to listen to me.
Dec 1, 2008. 4:42 PMwiley coyote says:
Me to, which is why I'm reinventing the wheel. The nutrient reservoir MUST be easily accessible for drainage/fillage/anything else WITHOUT disturbing the plants. I've found the plants themselves to be the biggest pain once grown. Generally speaking, the smaller the reserve, the more often you'd have to top it up.
Jan 28, 2009. 1:04 PMvrkelley says:
Wiley (or whoever wants to respond) I'm totally new to hydroponics and want to try lettuce/spinach. 1. How did you modify the pop bottle or Juice jug or whatever so that it's easy to drain the nutrient??? 2. Do you dump the nutrient on other plants or totally throw it away?
Dec 1, 2008. 5:31 PMwiley coyote says:
I would take it back. I made the same mistake when I purchased my first aquarium, but found that the testing wasn't necessary IF I kept up on the water replacement/exchanges, but that's just me. There's a lot of good info out there for the DIYer, but you need look no further than this website to find what you need to do it for virtually NOTHING. Good luck. If you crinkle the foil, it will reduce the ability of the sheet to focus the light and therefore burn. I use aluminized mylar myself and get only morning sun and they........uhhh................don't die ............ uhhh ....... much.
Nov 8, 2009. 5:42 PMbwpatton1 says:
WOW cool, when I start another aeroponics setup I will have to use these, because I have to go pretty far to get the mesh baskets.
Awsome Instructable
Feb 5, 2009. 10:51 AMstarterpistol says:
If you need a bag on the quick; minute rice sells those 5min rice bags that could work. Eat the rice first.
Feb 3, 2009. 8:30 AMvrkelley says:
Thank you! It's winter and our garden shops don't sell hydroponic medium, or nets. So I used an onion bag, 1 Gal Cranberry jug (no cutting), and this medium and tossed it under a fluorescent grow light::
2t Miracle Grow 1t Epsom salt (from pharmacy) to 1gallon water
1 teaspoon Dr. Earth to the 1/4 C peat, 1/4 C perlite
Onion bag lined with a thin paper napkin to prevent the medium from leaking
Total cost:
1.29 Epsom salt (enough for probably 50 plants)
0 Miracle grow (had it)
4.59 Peat (enough for ~500 plants)
0 Perlit (had it)
0 Lettuce seed (had it)
5.88 for 2 lettuce plants. A total of 3 jugs that competes w/ store priced lettuce
Plants are already sprouted using this method:
http://www2.ctahr.hawaii.edu/oc/freepubs/pdf/HG-42.pdf - will post in 6 weeks
Feb 3, 2009. 5:18 PMvrkelley says:
The paper was pretty flimsy so by the time the roots get that big, they should be able to bust through. The plant is supposed to use up all or most of the nutrient so there is little or no waste. You don't need a meter or any other equipment. If you try this please post your results
Jan 28, 2009. 1:05 PMvrkelley says:
Whopps let's try that again: Wiley (or whoever wants to respond) I'm totally new to hydroponics and want to try lettuce/spinach. 1. How did you modify the pop bottle or Juice jug or whatever so that it's easy to drain the nutrient??? 2. Do you dump the nutrient on other plants or totally throw it away?
Jan 28, 2009. 12:59 PMvrkelley says:
Thank you so much. What sort of medium is that?
Dec 1, 2008. 11:43 AMjuanj says:
Great idea! What are you using as a growing medium?
Dec 1, 2008. 1:11 PMwiley coyote says:
I like your "objectives". You'll also need to shield the nutrient from sunlight or algae will grow. Chip bags and the like work great as a UV shield in my experience.
Dec 1, 2008. 10:17 AMjareiko says:
Very resourceful!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:cfishy
