This is an easy to build vacuum chamber that is power with a garden hose. you can draw 30 cm of vacuum with your hose. simple and easy way to degas fluids like silicone for mold making without buying an expensive vacuum pump.
Remove these ads by
Signing UpStep 1Parts
1 - 6" x 24 " PVC pipe Lowe's $16
2 - 1/4 " x 12" x 12" acrylic sheets (www.estreetplastics.com) $12
2 - 1/ 8" x 12 " x 12" neoprene sheets (www.smallparts.com) $20
1 - vacuum Aspirator (csrscience.ecrater.com) $25
1 - vacuum gauge harbor freight $13
1 - 3" x 3/8" air hose harbor freight $4
Total = $90
I imagine that if you put a carbonated drink inside there, it would de-carbonate (I'd like to see a video of that, I can't find any)
Can you put a layout (schema) of the inner of the vacuum aspirator of step 2?
Acetylated wood
http://www.accoya.com/technology/
Titan Wood Inc.
modified wood by Accsys Technologies
http://www.ufpi.com/product/accoya/index.htm
Brug = Bridge Akkerwinde = name of a road
Sneek = name of a city in the Neatherlands
Brug Akkerwinde
Akkerwinde Sneek
http://www.bsbstaalbouw.nl/bruggen
http://www.achterboscharchitectuur.nl/page.php?id=97
http://nl.wikipedia.org/wiki/Houten_bruggen_bij_Sneek
(for me Google Toolbar can translate Dutch to English)
http://csrscience.ecrater.com/p/11338240/aspirator-with-garden-hose-adapter
you can get it with or without the hose adapter.
there is a detailed description there.
I'm no expert, but I've had/used one of these hose end vacuum aspirators since high school chemistry some 53 years ago, and it works exceptionally well.
And to answer your question, YES, it does work on the venturi principle.
In studying mine, it is fabricated to very small and tight tolarances which with 30 to 50 psi water pressure allows me to get a vacuum in the 25 to 28 inch range on my cheap vacuum guage.
If you build it well, one of your own making should also work well.
I noticer in the parts section, that bassman bought some of his components from an outfit called Harbor Freight and Tool, which also has a website and sells online. Check them out and maybe you can get one without having to build it yourself.
Harbor Freight has been a mailorder cataloge sales outfit for YEARS, but now has many stores across the USA, and now has added a website.
Much of their product is made in China, thus the relatively lower prices, but I take good care of all my tools and instruments, and get good service life for the price I pay. Every once in a while I do get "stung" by a defective product, but it's not often, and they usually "make it right."
And NO, I am NOT an employee of Harbor Freight, and my only connection with them is as a retail customer.
http://www.sciencemadness.org/talk/viewthread.php?tid=437&page=2
Jerry
I'll try making a link... CLICK HERE
Good Luck,
Jerry
That 6" tube has end caps and all kinds of other fittings waiting at the hardware store to be used with it. One or two end caps and some glue would seem to simplify things quite a bit. Or perhaps I'm missing something. If you want the ends to be removable there are threaded fittings too.
End caps are nice and thick and can be drilled for smaller fittings too.
Just a thought.
Not that you didn't learn a lot building yours.
I wonder where you came up with the vacuume asparater?
It's a venturi that creates the vacuum, the same as a car carburetor, that's how the fuel gets from the bowl into the throat of the carburetor. They sell vacuum generators but the only way I've seen them is compressed air to vacuum.
If you came with on your own your a genius!
Alan Hale
Fluidpower Specialist
I did a little google search for the aspirators and found many of them claimed 28" or 73cm draw with 60 psig.water pressure.
Have you tried to hook it to a pressure washer?
That should jack it up quick since the draw is based on the water speed.
great tool and instructable
Could you tell where i am wrong.
Thanks
Terry
If you get a really good electric vacuum pump (piston, rotary vane, etc.) and chamber, you can make a cup of water inside the chamber "boil" so much that it freezes. Even at room temperature, water is full of really hot molecules and really cold ones. It's the average of those hot and cold molecules that we call temperature. When you reduce the pressure, there's no air molecules pushing down on the surface of the water anymore, so those hot water molecules are able to leave the surface of the water easier, and the colder ones are left behind...lowering the temperature. Neat :)
There's a bit of info on Wikipedia about aspirators here: http://en.wikipedia.org/wiki/Aspirator
