Simple Double Neckalce by iamkeebler
This is a super easy and basic jewelery project that any beginner can do. All the supplies you can find pre-made at the store. (I found every thing at Michales)
What you need:
1 18 inch chain (the chain I got already came with a clasp on it)
1 24 inch chain (this chain didn't come with a clasp)
2 pendants that go together. I chose a bird and a tree.
A pair of Needle Nose Pliers
Step 1:
The first step really is the selection of the materials that you will be using. You want to make sure if you are going with two chains that don't look alike, that they at least have the same tone. It helps to make your piece cohesive. You also want varying length with this particular necklace. So I chose the normal chain as the short 18 inch chain, and the more unique chain to be the longest and to hold the larger pendant.
As for the pendants, again, make sure they "go" together. I chose 2 pendants in the same metal color with them same theme (nature). I chose one small one and a larger one to help balance the necklace out.
canucksgirl says: Mar 12, 2012. 12:00 AM
Very nice result! ;)
iamkeebler (author) says: Mar 12, 2012. 9:52 AM
Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
