Simple Drop Snare for Small Game. SUPER SIMPLE
2,034
59
Posted
Introduction: Simple Drop Snare for Small Game. SUPER SIMPLE
Step 1: What, Why, and For
So I've been looking around instructables for a good snare and haven't been able to find one. So I created this one. It is super simple and easy and designed for small game, birds, rabbits, possums, coons etc.
Step 2: Materials
About 10 feet of para cord
Knife
2 pointed support sticks
1 twig
Half a brick (or any medium sized stone
Ingraver (optional)
One small tree or sapling ( I used a low palm tree)
Step 3: Supports
Take your two support sticks and whittle one end on each of them into points. Then carve one small notch in each at the same level. After this place them about 1.5 inches deep in the ground about 8 inches apart.
Step 4: Pressure Plate ( Trigger )
Take your twig and cut it into size so that it is about the same length across as you placed the supports. Then make each end look like a flathead screwdriver. Now make sure it fits snugly inbetween the two supports in its notches
Step 5: Weight
When I did this I used my engraver to make a line all around the brick so the rope didn't slip of I would do this or you can drill a hole through it to attach the rope to it.
Step 6: Line
However you decided to attach your cord to your weight do it now. Now take your cord and loop it over a low branch above your supports and trigger. Now pull on the cord until your stone is about 4-5 feet off the ground. Then attach the stone free end to your trigger and make it so the trigger doesn't come off the supports while your tieing it to the trigger.
Step 7: The Death Sentence
Now make a slip knot and attach the free end to the rope above the trigger and balance the slip knot on the trigger mechanism.
Step 8: When It Goes Off
When it goes off the animals head will be caught in the slip knot and it will be hung above the ground being killed by suffocation.
Step 9:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
3 Comments
Well done. Tho a pulley of sorts would make sure the weight fall, or even some sort of lubricant. I use wire on the catch loop. If the critter isn't hung by the neck, it may chew its way free. But very well done.
If anything is unclear plz tell me and I'll update asap
