Simple & Easy Dimmer Circuit Using 555 IC for LED Strip Lights
5,558
89
15
Published
Introduction: Simple & Easy Dimmer Circuit Using 555 IC for LED Strip Lights
About: I like making new things from trash. For more cool content please subscribe to my YouTube channel @ https://goo.gl/BHxFf7
In this tutorial i will show you how to build a dimmer for the LED Strip Lights using 555 IC.
To build your own Dimmer Circuit using 555 IC you can watch the video embedded in this step or continue reading
Step 1: Parts List
***Parts List***
1. 555
2. 0.1uF Ceramic Capacitor - 2
3. 1N4007 - 2
4. 8 Pin IC Holder
5. 47k Ohm Pot
6. Resistor (1k & 120 Ohm)
7. BC547
8. PCB & wires
***Purchase or Affiliate Links***
Banggood
1. LED Strip Light - https://goo.gl/sCdDTX
2. 555 IC - https://goo.gl/eePxAN
3. Pot Knob - https://goo.gl/eZRT9L
AliExpress
1. LED Strip Light - https://goo.gl/1jgvRF
2. 555 IC - https://goo.gl/sb37S5
3. Pot Knob - https://goo.gl/MVeCHH
Amazon USA
1. LED Strip Light - http://amzn.to/2eVDY2J
2. 555 IC - http://amzn.to/2vgxMcD
3 .Pot Knob - http://amzn.to/2h2F5hN
Amazon IND
1. LED Strip Light - http://amzn.to/2vSfYkV
2. 555 IC - http://amzn.to/2uHPjc4
Note: all the purchase links provided are affiliate links
Step 2: Circuit Diagram
Construct the circuit diagram as shown in the circuit diagram. The circuit should be powered above 10 volts & the voltage should not exceed more then 14 volts. To control the brightness you can use the pot.
  • Creative Misuse Contest
  • Clocks Contest
    Clocks Contest
  • Oil Contest
    Oil Contest
15 Discussions
sonicam
Question 3 hours ago
This is exactly what I want to do with my LED strip - Thank you!
Do you know how I could add a simple sine wave oscillator to make it fade in and out automatically ? Or is that very complicated?
What is the voltage and current rating inputted here for 555 and Bc547
Excuse me,
i know how the 555 timer works
but how the whole circuit works ?
like what do the diodes do and what do the capacitors do?
thanks though
Really Interesting!
I have a question...
There are some resistors in the circuit but what is it the value of watt of the them?
1/2W? Or more? Do I need to choose the same value of the led strip?
Thanks!
instead of using tip31, is it possible to use an N channel mosfet(ex. irlz44n) in order to get more current?
I want to add a tip 31 transistor what kind of resistor should i use in R2,
because i use 120 ohms and led strip doesn't go up to full brightness
It is a good call to use a 555 for this application. In this times paople tends to abuse of microcontrollers in detriment of real electronics.
Pics, Attinys, Arduinos and other products come and go, but 555 will last for ever!
That's for sure.. 555 timer can be used in so many application like light detector, dark detector, schmitt trigger, timer & many more.
johnm1
11 months ago
Each LED in the strip uses 6.7 ma. The transistor specified has a maximum current rating of 100ma, which means it can only power 15 LEDs. The video shows of roll of LEDs being powered. Am I missing something or is a different transistor being used?
No, The transistor used is same as shown in the circuit diagram.
The transistor specified has a maximum current rating of 100ma which is true & its not ideal for lighting more then 15 leds but if you refer the datasheet - maximum current rating - continuous is rated at 100ma. Since we are using PWM there is no flow of current continuously (this is where i took the advantage of this transistor).
Now coming to the drawback of using BC547 - with duty cycle 50% or above you cannot use this for long time for that you need to replace BC547 with the transistor like TIP31.
