3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Electronic Light Sensor
video Simple Electronic Light Sensor
I may post an instructable for this.
This is a simple electronics project I set myself. I used vacuum formed plastic to make the case. To make it I simply made a solid wooden box and put it in a machine which melts plastic over the wooden model and 'sucks' it on tight. Once set you get a nice result.
To make the battery holder (although it's a little temperamental) I simply bent a piece of plastic using a hot wire to make a "||" shape the same width as the battery.
Lastly the circuit was made using copper clad board. I laid out my circuit plan on the board using strips of vinyl and then put the whole thing in a bucket full of etching liquid (can't remember the exact name!) which dissolved all the copper apart from what was under the vinyl which left a nice, neat circuit board! All that was left to do was drill holes for the components, a hole for the switch, and 2 holes for the LDR (light dependant resistor, A.K.A light sensor). I drilled a hole in the base to make it easier to remove.
If you head to the original YouTube video the description has a good use for this device!
http://www.youtube.com/watch?v=4Z1qShFmw3g
39 comments
Sep 11, 2009. 8:22 AMHiyadudez says:
Nice, looks cool, cant wait for the instructable (If you do make one anyway) Also i will make it if you show me how to. 4.5*
Sep 11, 2009. 12:53 PMHiyadudez says:
:S
Sep 11, 2009. 1:13 PMHiyadudez says:
Well I have a soldering iron in my tutor room in school, and we are allowed to use that after school, but no computer in that room, so Id probably have to take my laptop in :)
Sep 12, 2009. 5:59 AMHiyadudez says:
Yeah, Lol.
Sep 12, 2009. 10:11 PMkk khrab says:
Could you plz send me the circuit. ilike it it's very good. LOL
Sep 18, 2009. 5:10 PMzoltzerino says:
An a variable resistor to control the sensitivity of the potential divider.
Sep 18, 2009. 5:09 PMzoltzerino says:
This is the diagram I have, they match except I have put a diode across the buzzer running to the +ve voltage to protect the transistor from back EMF (electromotive force). Which version of Circuit Wizard is that?
Sep 19, 2009. 11:17 AMzoltzerino says:
They maust use the same component library / images. I presume you can simulate in Livewire. How much is it and who is it made by?
Sep 19, 2009. 11:16 AMzoltzerino says:
PCB wizard is only the PCB designing aspect of Circuit Wizard. Within Circuit Wizard you can design circuits and turn them into PCBs.
Sep 19, 2009. 3:33 PMzoltzerino says:
Livewire is made by New wave concepts, as is PCB wizard and Circuit wizard, they are all very similar.
Sep 10, 2009. 2:01 PMzoltzerino says:
Even though I know how to do this, could you please show me the circuit diagram anyway, so that I can see if you have done it differently. Love the music BTW.
Sep 11, 2009. 1:02 PMzoltzerino says:
thats fine. just write r for resistor and c for cap etc, just so i get a rough idea.
Sep 14, 2009. 10:03 PMmhkabir says:
You should improve your english. No offence. Kabir
Sep 15, 2009. 12:02 PMRMConstruction says:
Dude, he and i both come from England. We can both speak perect English, thanks very much!
Sep 16, 2009. 4:19 AMmhkabir says:
...witch, and 2 holes for the LDR (light dependant resistor, A.K.A light sensor). I drilled a hole in the base to make it ...
Not to mention some simple mistakes in grammar like long sentences and some meadering ones.
Sep 17, 2009. 1:15 AMmhkabir says:
few spilling mestakes
Nice!
Sep 11, 2009. 2:26 PMThe One and Only says:
Looks pretty good!
Sep 11, 2009. 10:32 AMTom Buckey says:
did you make this in school because i made something like this in scholl last year?
Sep 11, 2009. 10:49 AMTom Buckey says:
im making a tree house with my dad. i havent started but i cant wait.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
213
Author:Lowney(Lowney's YouTube Channel)
If you like this sort of thing then this is the sort of thing you'll like.
