Simple Electronics Project -- Infra-red Jammer
Published
Introduction: Simple Electronics Project -- Infra-red Jammer
This little instructable shall show you how to create a simple Infra-red jamming device which could be used for many hours of TV pranks.
Step 1: Infra-red Jammer - Parts List
For this project you shall need:
1 x 10K Potentiometer
2 x 10nF Capacitor
As many IR LED's as you please
Equal amount of 330 Ohm resistors for LED's
1 x 56 Ohm resistor
1 x 555 Timer IC
You can get most of these parts from an online retailer or electronics hardware shop relatively cheap.
Step 2: IR Jammer - PCB Layout
If you wish to create a PCB board for this circuit, I have a recommended layout here.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    4 Comments
    sir,
    i am about make this project for my college, it'll be of great help is you could confirm or make a video that indeed this project gives a output.
    Hi,
    This circuit is fairly simple and the 555 timer IC is fairly robust. Provided it is wired correctly, this circuit will work. Do not add too many LED's to the 555 output (pin 3) as the LED's may become fairly dim. If you wish to prove the infrared LED's are working, any standard camera should let you see the infrared light.
    Hi,
    do I need a 10K or 100K potentiometer? (list says 10K, Pic in step 2 says 100K)
    thanks
    Hi,
    Sorry for the confusion, the potentiometer should be a 10K linear
