3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make free Animations - Pivot Stickfigure Animator
Step 11ENERGY BLASTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
These aren't explosions. It's Dragon Ball Z styled Energy Bursts. If you're a kid, this is your favorite part of any show!
Here, I'll list the methods I use to make bursts.
Burst 1
I use this small burst for when energy balls hit the ground. Explosions are very hard to do if you're a novice, so instead settle for this quick method. This method
This list shows the order of frames I used to make the GIF below. This burst is good for about a second or two. I use it to avoid complicated sequences of explosions.
The Ball I used is about 1 /12 inches and size 164 if you measure it with a ruler (I should have worked on this....)
  • Frames 1-4 are the energy ball. This is used to show where it comes from. (Remember to add the color in this first part, or else the whole thing is basically ruined!)
  • In frames 5-6, I moved the ball closer to the center. Remember to think up the path the ball will follow before you start the animation.
  • In frame 7, the ball is below the center. Its close to the wall and the ground. (The canvas)
  • In frame 8, I changed the ball's size to 500.
  • In frame 9, I made it size 800, so it would cover the whole screen
  • In frame 10, I used the same size as in frame 7. I moved it a bit closer to the ground also.
  • In frames 11-21, I once again changed the size to 800 and changed its color to a clearer tone.
  • In frames 22-23, I once again made the color clearer
  • In frames 24-30, I made it even more clear.
  • Finally, In frame 21, I used a tone that almost resembles white.
Then you can continue the rest of the animation. Now try it!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
55
Author:Keith-Kid
So, hi, I'm Keith-Kid. Who the hell are you? I am one of the regulars here at instructables. I am a tried-and-true jack of no trades with absolutely no experience in any category. Still, I'm fun. My ...
more »
